Does anyone have drawings for a tray to mount 2 bottles on the back of a MM251 cart? I didn't want to re-invent the wheel!!
Thanks in advance.
Jim
Thread: MM251 Double Bottle Drawings ??
10-28-2006, 08:44 AM #1
- Sep 2005
- 72
10-28-2006, 10:18 AM #2
Doesn't that machine already have a double bottle rack?
Here's what the one for my TA 251 looks like. Nothing but a little platform to clear the welded on tray's edges, and a double clamp up top. Created a nice cubby to stick the bottle caps in though.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
10-28-2006, 03:05 PM #3
These should work if you like them. Disregard the reference to me making a drop in box. If you use this, the upper section will bolt to existing holes, you will need to put the legs on the lower one so that it fits into the existing tray. You will also need to extend the axel about 1" or so to clear the wheels. If you want to see pictures of it completed do a search un my username as there are recent pictures of the setup on my MM210.
Regards, George
10-28-2006, 09:40 PM #4
I built mine based on Georges design with a twist. I didn't want to mess around with the axle. I made the lower part to fit into the lower. It was pushed out a little to avoid the wheels. I only use 120cf and 80's on it. Larger ones will need to mess with the axle.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
10-28-2006, 11:47 PM #5
