    Default Need help with high temp camera
    Does anyone here have experience with a high heat camera that I can put inside a pipe to view automatic welding? Any help would be greatly appreciated.
    Thanks Dennis
    Feb 2006
    springvale me
    89
    you may want to ask that over on the shop floor talk form there are some real wizards over there.
    Where is the shop floor talk forum? I can't seem to find it!
    Mpls, MN
    1,790
    Build a cage that will insulate the camera from the temps and any spatter.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    deep in the suburban jungle
    125
    Quote Originally Posted by baffledwelder View Post
    http://www.shopfloortalk.com/forums/index.php
    Oklahoma City, Oklahoma
    304
    Default air cooled
    I haven't built the exact setup you are asking about, but I have built something similar before. What I did was to build a box and then fab up an air connection to it. Then dial down the regulator on your shop air system and put a nice "breeze" through the box. Not only will it ventilate the box, but the decompressing air with have a slight refrigeration effect as well. The one down side to a welding environment would be wether or not you are back purging the weld area. If this is the case, I would also install a second line from the box as a vent tube to make sure there was no mixing of shop air and argon. Also, just depending on your exact environment, you may want to make the connecting tubes out of metal tubing to keep from melting a rubber or PVC line. SSS
    Indiana
    12
    Default high temp camera
    Why not just use a welding lens over the end where you can watch it. We do this when we set up out orbital welder to see what is going on. Just tape one on the end.
    I appreciate the replys , but I am asking for help on finding a camera to do this. Can anyone tell me where to get what I want? There are a lot out there and they get expensive. The cost really isn't that big of a deal being that we just spent 2 weeks doing rework on a part becayse we could not see far enough in the pipe.
    Mpls, MN
    1,790
    How big is the pipe, and how far in do you need to go?
    A lipstick camera attached to a computer interface on a little remote controlled dolly (think "radio controlled car") would be small enough for most pipes and heat shielding would be very simple, with the cable being the most sensitive part of the rig (if you use aluminum wheels on the dolly).
    What are you looking to spend?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
