Hi im new to this plasma stuff but i own my own little buisness right now and i wanted to get into cutting sheets of like 10 gauge and i was wondering what is the good plasma cutter to use or to buy
Results 1 to 7 of 7
Thread: wondering about plasma cutters
10-09-2006, 07:23 PM #1
- Oct 2006
- 2
10-10-2006, 04:40 AM #2
Plamsa Cutter
Miller, I have a small one, and not good with numbers or models, but it runs on 120V, and needs to hook to an air compressor, I think the model is a Spectrum 375, cost was about $1,100.00 and I love the thing. Works wekk.
check out Miller, they also make Hobart and a nice 3 year warrenty.
Mushroom
10-10-2006, 08:20 AM #3
I have a Spectrum 375 at my place. It is great for sheet metal and other small cuttings. Personally, if I was going to do it over, I would step up to the 625. Granted, it's about twice the cost, but a bigger machine can always be turned down for light work. It can get pretty frustrating when you have to drag out the torches just for that one cut that's too big for the plasma. If all you are planning on doing is the lighter sheets, then the 375 would be well worth the money. Just remeber to look at what you might be doing down the line and not wish four years later that you had spent a little more. Oh, and just a personal thing with me, I run extra filters and have a dryer on my air system to make sure things don't get contaminated with dirty/moist air. Happy shopping!! SSS
10-17-2006, 01:16 AM #4
- Sep 2005
- 76
Plasma cutters
I agree with all of the above - I'm a hobbyist, dollars to doughnuts it costs me $50 to fill my portable Oxy-Act tanks. Granted it cost a few bucks to buy my plasma torch (Spectrum 375) and a compressor to drive it ($500) - now my only cost is electricity.... SSS is right - look 4 or 5 years into the future and buy equipment that supports growth.
Steve
10-17-2006, 07:09 AM #5
For what you want to cut the Specturm 375 will do the job, I have one and its great as long Ias I don't try to cut anything beyond its capabilities. If I were getting a new one I would spend the extra few dollars and get the Spectrum Extream 375, very nice cutter IMO.
Regards, George
10-17-2006, 06:59 PM #6
- Feb 2006
- springvale me
- 89
I have the spectrum 375 it works great especaly if you switch it over to 220 with the switch on the back of the machine it cuts 1/4" with no problem the specs on the 375 are1/6 stand off rated 3/8 quality cut 1/2" sever 5/8". drag cutting 5/16 rated 3/8 quality 1/2" sever you just have to adjust your cut speed to get what you want. hope this helps.
10-17-2006, 08:53 PM #7
plasma machine's
check out millers web site under products.
I own A 2050 and it is a good machine I mainly cut 1/4" But there is that odd time that I do get asked to cut some 3/4" plate and with this machine no problem.on single phase If you want stay with 1/4" and lighter for now then the 375 or the 625 will do you just fine. If you are cutting aluminum I have allways had better luck with a skill saw.Way less cleanup after my cut.
hope this helps ya make a wiser decission.
