Results 1 to 9 of 9
    May 2006
    Kansas City Missouri
    84
    Default Remote current control for tig
    Thinking about purchasing a remote fingertip current controller for my Sycowave 200. I'm tired of trying to push the foot pedal down with my elbow or knee when I have to weld off the bench. I know nothing about these items any and all advice is welcome. How do they attach and which ones to go with. Thanks......gear
    Sep 2006
    Washington
    2
    What about a small stool you could sit on when you're away from the bench, that works for me.
    May 2006
    84
    The problem is I don't have a large table to work from. I have to use my garage floor to lay out anything that has any size to it. I seem to be making a great deal of ramps for trailers (easy access for quadrunners) lately.
    Aug 2006
    near rochester NY
    9,881
    arc-zone caries a few diferent designs. from what i have herd they can be a bit dificult to get used to as its a lot for the hand to do all at one time. but once you get the hang they can be usefull, also some put the pedle between there nees like the thie exersizer susan summers used to push.
    here is a link to arc zone. nice people to work with, frendly and they send you a sticker and a pack of M&M's with your order
    http://www.arc-zone.com/catalog/web_...=6892375_53099
    good luck, you could also look around on e-bay for some deals on ones others have given up on. not every one is willing to stick it out long enough to get the hang of it.
    Jul 2006
    181
    The finger tip control that can be attached to the Tig torch and hooked to the Sync 200 is a RCCS 14 Miller Part # 043688.
    Gary
    849
    Quote Originally Posted by gearhead View Post
    What about possibly building some metal horses to work off of ?
    Aug 2006
    near rochester NY
    9,881
    how about a look at thease ramps??
    Jan 2006
    long sault ontario canada
    114
    Default complicating your life
    Unless your into really have tight paramitters i would suggest setting the m/c where your comfortable and welding away!
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    Oct 2006
    5
    I just recently bought a Sync 200 and due to the fact that I'm welding a roll cage in my race car, I had to have a remote. I bought the parweld with the rheostat and switch from welding depot. www.weldingdepot.com
    It runs about $250 and uses standard collets. It also has a flexible head that is great for getting into those tight spaces. The only complaint I have is that you have to hold the button down while you're welding. Highly recommended.
    Tommy
