Page 66 of 71 FirstFirst ... 16566162636465666768697071 LastLast
Results 651 to 660 of 705
  1. #651
    Default carbon rods
    I have used carbon rods to fill worn out hitch pin holes. Put the carbon rod in the hole and weld around till the hole is full to your standards and pull the rod out and you have a perfectly round hole you dont have to try and drill
  2. #652
    Oct 2012
    Neosho Mo
    79
    If you can identify the rod type by the smell of the flux smoke
  3. #653
    Dec 2012
    Simcoe Ontario
    104
    Default You might be a weldor if....
    YMBAW if you think tungsten is an acceptable toothpick
    When others say they are a welder you roll your eyes and wonder if they can actually weld
    You buy a cheap Lincoln so you can make enough to buy the dream miller
    You always carry at least one flashlight at all times
    You think 308L tig wire makes nice jewelry
    You got a tig torch tattooed on your hand
    You discover nomex/ Kevlar laces and buy the whole box cuz they might last a little longer
    Your sunglasses are cutting glasses
    You think every boiler tube should have been welded by you
  4. #654
    Dec 2012
    Simcoe Ontario
    104
    Rather than set up your torch you use 6010 to cut almost everything
  5. #655
    Default 3 years and going strong!
    in the same sentence where to find a church or some crack cocaine ...... Lol true story .
    That was funny stuff.
    THe one about the asking the fire watch if somethings on fire and its you!
    YMBAWI you have a whole cabinet of consumables from different jobs. (That ones are little secret though...)
    -- you can read a whole sign of words on a window while standing behind it!
    -- you find this thread after 3 years and reread most of it again. This is great!
  6. #656
    Only got to page 32, but gotta add mine........
    YMBAWI: your company installs a new time clock that is fingerprint operated, and you have to use a pin pad instead because it won't read your prints
    YMBAWI: your changing your 1 yo daughters diaper and you wonder if her diaper rash cream will soothe the flash burn on your arm (between the bottom of your shirt sleeve and top of glove, inside left arm)
    YMBAWI: the door bell rings at 3:22am, because your buddies were rock crawlin and broke the jeep again and need you to weld it back together so they can get to work in the morning, or you have to put the TB275 and some 6011 in the truck to go fix the jeep broke on the rock/in the mud
    YMBAWI: your wife buys a beautiful brand new pair of red wing boots, but you have her take them back because they have laces, (and we all know laces get expensive)
    All true!
    P.S. so many of the posts are true lol.
  7. #657
    Jan 2013
    Ohio
    15
    Ymbawi your in jail and all you can do is look at the welds and think they all coulda been done better or what you can use to break out overlooking the concrete.
  8. #658
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by Guesswho392 View Post
    Sounds like you have a personal experience with this.
  9. #659
    Mar 2013
    You might be a welder if your daughter hugs you and tells you that you smell like metal.
  10. #660
    Dec 2012
    5
    You clean stainless with acetone wearing your welding gloves and go to tack your parts together and spontaneously start your whole hand on fire... Not once but three times.
