Page 47 of 71 FirstFirst ... 37424344454647484950515257 ... LastLast
Results 461 to 470 of 705
  1. #461
    Jan 2009
    Virginia
    4
    YMBAWI : You break for lunch. You don't remember putting ketchup on that sandwich in your hand. Then you casually realize that your bleeding again.
  2. #462
    Mar 2008
    Battle Ground WA
    179
    YMBAWI---you pick up a new striker and chipping hammer every trip to the LWS and then when you can't get the seat to move in the truck you find the last ones!!
    YMBAWI-if you use the OA torch to find your soap stone that "must have fell out of your pocket behind the steel rack?
    YMBAWI---if you use the cup and cork off your stanley as a plasma cutter guide!
    YMBAWI----If you were offered a job as a beach lifequard and you turn it down cause you have a Fab job that you started and you are determined to finish!!
    Tim
    Retired Elevator Consrtructor Local 19 IUEC
    AK bush pilot (no longer in AK) too old and no longer bold)
    Chaplain CMA chapter 26
    Dynasty200dx (new and loving it)
    MM-252 (NEW AND LEARNING IT)
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
  3. #463
    Mar 2009
    Corona, CA
    213
    Default You Might Be A Welder If:
    You've been fixing a crack in a friends transmission bellhousing overhead, before feeling the wonderful sensation of molten aluminum brush past your genitals.
    You've finished a weld on the roll cage you were fitting to a miata, before squirming around like a worm on a fish hook, trying to get the spatter out of your welding leathers.
    You've ever been set on fire from grinding sparks, after finishing your welds unscathed.
    You look like you changed skin colors after grinding all your welds flush with the base.
    You can no longer go to a car show because you tear the welds on the displays apart more than you look at the cars.
    You forget that you are on a time limit at the library, and almost miss posting this.
  4. #464
    Mar 2009
    DFW, Texas
    71
    YMBAW if you try to convince your wife that the rust stains in the driveway enhance the value of the home, just like a professional stain job..
  5. #465
    Sep 2008
    southwestern ohio
    272
    YBAWI You were changing tires at a friends house on some farm equipment with a 1/2" breaker bar and after trying for a while you think D@mn I wish i had a torch with me
  6. #466
    Mar 2009
    Pa
    43
    If you have done the one footed hop from the hot sparks that fell into your boot and down between your toes.
    Miller 330 A/BP Tig
    Millermatic 250
    Spoolmatic 30A
    Hobart 175 mig
    Miller Regency 250 w/ wire feeder
    Bridgeport vertical mill
    Delta bandsaw
    Rockwell lathe
  7. #467
    May 2009
    7
    Quote Originally Posted by racebronco View Post
    you analyze the welds on everything while shopping whith the girlfriend..
    .... If you say Girlfriend???? What's a girlfriend??????
  8. #468
    You can still count to 21 but around 19 of them have been burnt or blistered.
  9. #469
    Lake of the Ozarks MO
    3,537
    YMBAWI....you actually know which parts of your body you have not branded yet. And after 37 years I am down to one..... (my @$$hole) And I ain't kiddin'
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  10. #470
    Sep 2008
    southwestern ohio
    272
    if you have a torch an the kitchen table
