Page 3 of 71 FirstFirst 123456781353 ... LastLast
Results 21 to 30 of 705
  1. #21
    4
    Default You might be a welder if.......
    You go to the doctor and find out you are 10% steel from grinding.
    You stop hitting the tanning booths. Your mig tans great!
    The guy at the steel dealer knows your first name.
    Your neighbors know when you are home from the grinder.
    You have steel withdrawls.
    Your welding helmet costs more than your car.
    CB
  2. #22
    Brookfield,MA
    103
    .....If you tought yourself how to use chopsticks using 6011 1/8 cause you forgot your fork at home.
  3. #23
    304
    if every new shirt you buy has holes in it and someone asked you are you trying to start a new fashon but you jsut say no i just weld....
  4. #24
    Suffield, Ohio
    344
    When your pants look like you bought them at American Eagle or Abercrombie.
  5. #25
    British Columbia
    24
    Smile weldor if
    you lay around on your back all day screaming for more money ,more rod and more heat
  6. #26
    Oklahoma City, Oklahoma
    304
    Anyone has ever walked past you and said that you were on fire and you calmly responded..."I know"
    Along those lines:
    You know exactly what your ratio is between pain tolorance and dedication to not breaking a bead in process.
    You immediately know the difference between the smell of burning leaves and burning fuel lines.....don't ask!
    SSS
  7. #27
    BALCO BURNER Guest
    Talking
    your arms look like you had a bad case of chicken pox as a kid
  8. #28
    Jan 2006
    Antigonish, Nova Scotia, Canada
    33
    ..you spend more money on heating your E7018 than your own house.
  9. #29
    304
    you've ever had the police called on you for driving off from a pump when you filled the truck and had to move to another pump and fill the machine. Onan is (or at least was) owned by Cummins...you'd think they could burn the same fuel, right?
  10. #30
    3
    when your wife says "what's that burning " and you casually say "nothing " you decide to take a look, and the rags you had laying on the ground have turned into a bonfire,and you have to ring 111..
