Page 23 of 71 FirstFirst ... 13181920212223242526272833 ... LastLast
Results 221 to 230 of 705
  1. #221
    Nov 2007
    Appleton WI
    59
    Quote Originally Posted by racebronco View Post
    you analyze the welds on everything while shopping whith the girlfriend..
    God that's a good way to kill time when I'm doing something boring. I find myself doing it alot more since I started actually welding for my supper a little over a year ago. I was an auto mechanic for 10 yrs. before that. Now I actually enjoy going to work. At leat as much as you can I guess.
  2. #222
    Nov 2007
    Appleton WI
    59
    [QUOTE=MattT;4436]You might be a welder if...
    You've ever set your Boss on fire I told him to move[/QUOTI shoulda done that after my last review!!!:
  3. #223
    Nov 2007
    Appleton WI
    59
    Let me fix that.
    That's what I shoulda done after my last review!!!!!!
  4. #224
    Talking Ok, guys, here's one!!!
    You might be a welder if...........................
    You quickly log onto "www.millerwelds.com's" message board to discuss welding issues, help out a fello welder, seek welding advice or solutions and come up with a completion to the "you might be a welder" phrase!
    Good game SSS, thanks for the laughs
  5. #225
    When you are tired of tacking and just want to burn some rod.
    Some one gives you a 1/4" rod and you get to crank the machine up flat out.
  6. #226
    Fraser Valley, BC
    593
    Quote Originally Posted by mcostello View Post
    That's my idea of livin it up.
    On a side, got to try that at school the other day to test a welder. It had been blowing breakers as snacks so the electricians wanted to probe it for amp readings. 1/8 7018 at 120'ish and it pulled 70 amps at the breaker. Biggest rod in the parts room @ 180'ish and it pulled 102 amps at the breaker, Electricians eyes almost popped out of his head, I think that made his day too.
    By the way, doesn't that number sound a little high, welder is an old Dialarc 250 AC/DC?
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
  7. #227
    Noth Dakota
    505
    You might be welding too long when you change tanks then the wire burns really hot and fast and it takes a while to figure out you put on a tank of Argon...
  8. #228
    Nov 2007
    Bosque Farms, NM
    10
    Your best sunday church clothes have spark burns and people think its the latest fad...so they ask u get them !!!
  9. #229
    Noth Dakota
    505
    You might be a welder if:
    Your portable work bench is an empty 55 gal drum supporting a 4'x4' sheet of 3/8 steel.
  10. #230
    Nov 2007
    Appleton WI
    59
    It's common to walk into to work to find broken metal objects on your workbench accompanied by an IOU for a case of beer
