Page 51 of 71 FirstFirst ... 41464748495051525354555661 ... LastLast
Results 501 to 510 of 705
  1. #501
    Question
    Also YMBAWI you notice the excellent craftmanship of dirt dobber nests!!
    They do make some nice weaves, don't they?
    Here's a nice 4F!
  2. #502
    Sep 2004
    Buffalo, NY area
    37
    You do a visual inspection of the welds at D-i-c-k's (has anyone else seen all the welded stuff in this store?!) Sporting Goods and point out all discontinuities you can find to your wife...and she gives "the look" followed by an eye roll every time...
    Tom
    Dynasty SD
    Millermatic 130
    "Too Bad Those Who Know It All Can't Do it All"
  3. #503
    Jun 2009
    greenfield new hampshire
    889
    Default this actually happened today
    your eyes are so bad from all those years of welding that you cant figure out why your weld gets worst each time you put the wire brush to it, it wasnt wire, yard sale plastic (small brush)
  4. #504
    Jun 2009
    12
    YMBAWI,
    If you spent the last couple hours reading this and actually LOL!!
    or
    If your girlfriend tells you to stop picking your noise and showing her the black crap you find!!
    Best Regards,
    Dennis Johnson
    http://www.johnsonhaus.com
  5. #505
    Aug 2009
    4
    You joined this forum just to post to this thread.
    "If your girlfriend tells you to stop picking your noise and showing her the black crap you find!!"
    You try to use that black crap as filler metal.
    You refer to your O/A rig as the blue tip wrench.
    When your boss tells you to take the scrap steel to the recyclers and you dig through it for anything "usable" first.
    When the "usable" pile is bigger than the one going to the recycler.
    Working for a brick/block mason and you have almost as many pallettes of "usable" scrap as you do brick and block.
    When your workmates look at your steelies and tell you it's time to buy new ones and they aren't even broken in.
    When you drop everything just to weld up a broken set of cheap brick tongs.
  6. #506
    Mar 2009
    DFW, Texas
    71
    when you realize that magnet induced arc blow is also descriptive of how you feel when it happens.
  7. #507
    Aug 2009
    Southern California
    6
    When you Forget your ground clamp all the time. Or forget to turn on your gas every single time you strike your first arc for the day..
    When you set the gun down on your mig welder, walk away, comeback later and theres wire EVERYWHERE!!! And ya try to clean it up before anyone sees.
    Oh Wait? wrong thread..
  8. #508
    Jul 2009
    Colorado
    71
    you have to go to the eye Dr. because that microscopic metal flake won't come out and your eye swells shut. The Dr. removes the flake and tells you to come back next week to have the rest of the rust removed.
  9. #509
    Jul 2009
    Colorado
    71
    You start a 100% wood project and end up needing to weld something to complete it.
  10. #510
    Nov 2007
    Appleton WI
    59
    [QUOTE=Big Tattoo;202390]You joined this forum just to post to this thread.
    When you drop everything just to weld up a broken set of cheap brick tongs.[/QUOTE
