A few months back I purchased a 1995 Miller Legend AE200 with an onan motor. It was sold by a large equipment dealer and was "inspected and repaired" by the company that sold it. Shortly after I purchased it (one week, 2 hours of operation), it stopped making a consistent spark and wouldn't charge the battery. I took it in to be looked at by a shop, and they told me that my magnets on the flywheel had let go and would need to be replaced. The total cost was about 2/3 of what I had paid for the unit and I couldn't justify spending the money. Is this something that a repair shop should do, or is it something that I can get the part for and do it myself? (I am fairly mechanically inclined.)
Thanks!
Results 1 to 3 of 3
Thread: Legend AE200 help
09-19-2006, 12:52 PM #1winston Guest
Legend AE200 help
09-21-2006, 05:11 AM #2
- Feb 2006
- Hortonville, Wisconsin
- 6
Winston, If you pay for shipping, I have a spare flywheel from an Onan Performer engine. Let me check first in the books and see if the one I have will fit. The one that I have is from a Legend with an 18hp engine. Let me check and I will get back to you. If you want to PM me I will give you my phone number to call.
Spectrum 375 plasma cutter
Spectrum 2050 plasma cutter
Millermatic DVI with 3035 spool gun
Millermatic 350P with 30A spool gun
Dynasty 300DX Tigrunner
Miller Legend
Miller Pipepro 304
09-23-2006, 09:44 PM #3
- Feb 2006
- 19
It`s not hard to change,if you don`t have a puller use a small pry bar and put it behind the flywheel on the key way side.put light pressure on it and tap on the crankshaft with a hammer just be careful not to damage the threads putting the nut back on so it`s flush with the end of the shaft usualy works.
