Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    3,951
    Hey bob, what keeps the small spool from unwinding?
    The spring pushing aganist it. Its between the spool and the hitch pin....Bob
  2. #22
    3,951
    Quote Originally Posted by Arcs&Sparks View Post
    I found it on the Atlas Welding Accessories website. They sell direct and they supply distributors. Also found it at WeldingSupply.com for $15.55. Some distributors stock these.
    Thats fine too. But i have 4 of them with different wires and since i have a welder and a shop to make stuff i built them. But i could have just as easy ordered four and spent 80 bucks and watched more Duck Dynasty reruns ....Bob
  3. #23
    Mar 2013
    4
    Default Here is a picture of the Universal Spool Adapter
    I found this on the Atlas Welding Assec. website but they are available from some welding distributors and other websites.
    Hi Guy's, I have a pile of 4" spool's of .023 for thin sheetmetal. I want to use them on my MM185 but can't because of the 5/8" spindle hole. I was going to rewind them on an empty big spool but don't have the time. So i thought of an adaptor, i don't have time to make one for a few days but i will throw out the idea. Use a piece of 2" black pipe the width of the big spool. Bring 2 arm's straight out with a 5/8" hole to hole the 4" spool, you can tighten the 5/8" nut for some tension on the little spool. Then you will need an arm downward like a kickstand to keep everything level for the wire to go into the drive. I have some 1/4" bolts with rubber feet i plan to use. Hey give it a shot. Sure beats buying a giant spool of .023 if you only need a little. Will post some pics in a few days...Bob
    One other thing it would be good for those small rolls of flux core if you want to try flux core welding without buying a $50 roll.
  4. #24
    Mar 2013
    4
    Thats true, when I have time I will fab some things but for the price of a hamburger and fries I purchased the adapter and started to weld when I got it back to the shop. If I had time I would carve my own duck calls. Maybe a guy could machine a stainless duck call?
  5. #25
    3,951
    Thats fine too. Post some pics of your welding when you get some time...Bob
  6. #26
    1,312
    Here is mine using PVC. Filed most of the Nylon out of the nyloc nut to get the tension. (easier to turn/tighten) Works with Lincoln/Miller Machines just perfect. Esab multimaster and Thermal-arc feeders also .Lines up just right on the feeder.
  7. #27
    Mar 2013
    4
    Default Universal Spool Adapter in use on S22a and Millermatic 250
