Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Salem ,Ohio
    3,953
    Cool Ring is in the mail.
    MM your ring is in the mail. Glad to have helped...Bob
  2. #22
    Sep 2006
    17
    Well ... that's the prettiest looking ring I've seen in a long time ... :-)
    Thanks Bob, and let me know if there is ever anything I can do for you.
  3. #23
    Oct 2006
    Indiana
    12
    Default Cast Iron.
    The shape of the cast iron drill press part looks like it could be fabricated out of some pipe and other metal pretty easy or have a local machine shop make one. Or like some of the others have said, Hi nickle rod or wire and pre-heat and post heat , cool very slowly. Good luck
  4. #24
    Oct 2006
    British Columbia
    500
    Cool Cast welding
    You must pre heat the casting 350 to 500 deg F
    with out delay the welding must take place very quickly after pre heat
    You must also Lightly peen the weld after each bead and alternate the welding on both sides. you must grind out both sides making a 60 to 90 deg bevel
    you can use 7018 because your break is not moer than 60% of the casting
    Now here is the fun part what cast rod are you going to use?????
    there is Aws category RCI , ECI , EST AND ENI cast rods
    good luck
    Darmik
  5. #25
    Jan 2006
    long sault ontario canada
    114
    Default just my 2 cents
    There is a lot of good quality cast rods on the market I would vee out one side and bolt it back up .Then i would postion tack on the press remove it to the bench weld it up ,all this time the peice is pre-heated to about 100 degees ,or as hot as comfortable to handle >check it a couple of times for fit up,Vee the other side and weld up The whole time gently peening let it cool slowly and youll be good to go till your new peice comes in!
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
  6. #26
    Feb 2009
    Island Falls Maine
    562
    Exclamation cool slow
    alwase preheat and let it cool slowle. keep the torch on it and let it cool slowle
  7. #27
    Feb 2009
    202
    Default welding cast iron
    it can be done & i do it all the time when i need to with good results...i take nickle base stainless steel stick rods,beat the flux off,sand it down good & clean...clean the cast iron up & V it out real good with a bevel...preheat with the oxy/ace torch & tig it back just like you would Stainless steel...it can be done
  8. #28
    Mar 2009
    Papillion, Nebraska
    19
    Montana Man;
    It may be cast steel. Not a whole lot of stuff is made out of cast iron anymore. Cast steel will weld much bettter. If it's Chinese... who knows?
    I take it you are from Montana or in Montana. I was born in Sidney, Mt.
    Good luck. Sounds like you've got some guys to help out.
  9. #29
    Nov 2006
    Lake of the Ozarks MO
    3,594
    Quote Originally Posted by kmomaha View Post
    Montana Man;
    This is a 2 1/2 year old thread. Even tho much of the info is still relevant many of the people on it have not been back on here forever. They are not gonna answer you back.
    MKSWelding has dug up about of a dozen or so of these now
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
