Results 1 to 3 of 3
    Oct 2005
    North Central Indiana
    783
    Default 300 Pulsed TIG (DC GTAW) Control Question
    Does anyone use Millers PC-300 Pulsed TIG (DC GTAW) Control unit? I keep hearing about the benefits of pulse and was wondering if the 300 pulse control unit would make my 180SD pulse/operate as well as machines that come with factory installed pulse? Thanks
    Can be used with AC or DC welding power sources with, or without, built-in HF or with external HF units (HF-251D-1 or Snap Start II). Non-inverter power source uses 0.5-20 pulses-per-second. Inverter power sources uses 0.5-20 or 10-300 pulses-per-second.
    Your 180Sd will easily handle the PC300. It will run just like a factory installed unit!
    A-
    Oct 2005
    783
    Thanks ASKANDY. I like my 180SD, and it's really all I can afford right now,(graduation and a wedding to pay for this summer) adding the 300 unit might be the cheapest way for a proud but broke father to satisfy the pulse itch.
    I'll have to talk to my welding guy about it. Thanks again
