Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 64
  1. #51
    Oct 2008
    Default Welding Beer cans
    Hello,
    Currently I have 6 250's in the shop that I instruct in. I have found that using a piece of angle iron to help fit the 2 can together is beneficial. Pre cleaning the cans with a stainless or brass wire brush is a must. My students practice with 1/16" 2%thoriated and we use 4043 .030 spool gun wire. After the 2 cans are tacked, the arc must be concentrated in the center of the tack to begin the welds. I have found if the cans are not cleaned properly by remiving the clear coat the arc will take the least path of resistance and melt a hole in one of the cans. A steady hand is a must, and the rate at which the filler metal is added is essential.
    Hopefuly this helps,
    Adam
  2. #52
    Default welding beer cans with a dynasty 200dx
    A few tricks for welding the beer cans with a dynasty 200dx:
    First thing is punch a hole in one of them so that the expanding gases dont blow out when you close up the last little bit of the weld.
    second, use 1/16" or even .040" electrode, either 2% thoriated, ceriated, or lanthanated and put a taper on it just like you would for welding on DC. maybe not quite as sharp.
    A/c balance around 60, frequency/HZ at about 100-120
    Filler metal no bigger than 1/16"
    use 4043. 4047 is even better because it has slightly lower melt point and wets out better with lower heat.
    If you really want to strut, run a really light pass around the ridge of each can where the weld will be, in addition to all the above.
    Good luck,
    Jody
    www.weldingtipsandtricks.com
  3. #53
    Oct 2008
    NY
    Default Welding beer cans
    Hi
    Is this what you had in mind?---I having been doing this for years using a Miller Snycro Wave 250 :-)
  4. #54
    Mar 2008
    Battle Ground WA
    179
    Tecknition,
    Congratulation on the purchase of the 200dx, I am picking mine up "today". I am as well looking for a new Plasma cutter, we will stay intouch and compare notes!
    Tim
    [QUOTE=teknition;2770]I recently purchased a Miller Dynasty 200DX and want to practice welding thin aluminum.
  5. #55
    Mar 2009
    jasper, ga
    Not two cans together, but this part of the can is thinner.
  6. #56
    Oct 2008
    taxachussetts
    416
    and here is mine. i only had 3/32 filler and haven't welded alum in a long time. i should have toke more time with it but just banged it out to show some one. and i didn't use any fancy settings. it is the second one i did, the first one had a grounding issue and the hole side of the can blow out.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
  7. #57
    Mar 2009
    Corona, CA
    213
    Ive found that Monster cans work rather well...just scotch brite the paint off, and get bare alum...go to town.
    I used an 1/8th" 2% thoriated electrode, used some 1/16th" rod (3003 I think), and set max at 15 amps. On a Lincoln. Gas flow was about 10cfh.
    Ive tried welding cans the same way with a miller...doesn't seem to work as well, but again, so many settings I had no clue where to put them all.
    The best bead I ever had was on one of the 24oz'ers and I ran from the top ridge to about an inch from the bottom before I finally burned through. Great practice for consistency, and pedal control though!
  8. #58
    Oct 2008
    taxachussetts
    416
    Xwelder said the side was harder so here is my side shot. i have to weld some alum tomorrow so i used a piece of the stock. it's 1/8.
    the two holes are from the cup. (the sides sure are thin)
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    miller 211
    evolution rage 2
  9. #59
    Mar 2009
    jasper, ga
    Quote Originally Posted by vin-man welding View Post
    That's impressive.
  10. #60
    Mar 2009
    Corona, CA
    213
    ...I never welded anything to it...props. I just ran the bead and tried to keep it consistent.
    Imma have to find myself a tig welder I can use, and keep playing around.
