Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 64
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by blazehaze69 View Post
    Hey Tek, can I assume you're drinking the contents of the aforementioned cans? Stay away from Old Style or Millers- bad aluminum! I know you folks up north don't celebrate the 4th of July, but have a great day anyway!
    I hope your talking about Canadians. I couldn't imagine ANY American not celebrating the 4th of July, Independence Day.
    I'm going to go weld some of the new Bud Select Aluminum Bottles. They come in a 4 pack so I'm might have to go back to the store to get more "metal" to weld.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
    Nov 2007
    Southern Louisiana
    421
    are you welding the bottom together or trying for the middles?
    for the bottoms it's quite easy, keep the parts clean of oxide, keep the energy low and run the arc mostly on the filler to pull more energy out. The tops are a bit harder because they are rolled and you get the side of a stressed thin piece of aluminum. If you are welding the sides-good luck I haven't been able to do it without a plasma welder, not cutter, welder even then it was hard.
    Be careful of the fumes, they made me very sick the first time around. The inside of the cans have some coating that is nasty in the heated fume state. I think they put it in there to keep the content of choice from tasting like aluminum. There are even some concerns about what kinds of disorders are coming from aluminum food handling equipment, so just be careful and enjoy the prep work
    Mar 2008
    Baltimore, Maryland
    315
    Quote Originally Posted by diamondback View Post
    Thanks for the heads up. I didn't know that, so I will definently(sp for the spelling police) wear my half mask.. Might have to take it of to do some more welding prep.
    20Ton press
    Sep 2008
    Omaha, NE
    447
    Pulled this off today on after working on it here and there since i've owned my own TIG. I honestly thought i'd never get it this fast, but thatnkfully i'm on the right track now at least. I was using 1/16th rod and tungsten.
    Machine settings were as follows
    Start amperage 10A _only one changed
    Main apms 30
    balance 70
    frequency of 60hz made it realy easy
    Also did it with a freq of 140hz while pulsing at 4pps and using 80/20 on the peak and background.
    Althought they weren't flawless, it's my best effort so far, INstead of welding 1/3 inch and then burning 2-3 holes through i only burned 3 small holes on the places where i had to stop and then get teh puddle flowing again. NOt bad IMO, i'll try and get pics up later. Gotta go to work here soon. Just waiting on my Dogs to get "backyard business" and breakfast done so i can load up and head out.
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Sep 2008
    Delta B.C.
    33
    Can stainless steal wool to clean the filler rod get rid of the glob?
    Millermatic 135
    Feb 2008
    889
    I wouldn't think so because it's probably not a cleaning issue... the deal is that since the base metal is so thin, he can't get it much above the melting point without blowing a hole in it, so when he dips the rod in, it sucks enough heat from the weld pool to teter on the phase change. It's basically trying to solidify on him and has little if anything to do with dirt.
    Chicago-ish
    282
    As "Beer Can Moderator", I will delete any future posts where the thread starter claims to even try to weld cans together, when the post doesn't include pictures. Sorry, guys.
    Sep 2008
    Omaha, NE
    447
    Quote Originally Posted by spotsineyes View Post
    I will post pics of my progress as soon as i get back from eating (leaving in 5 minutes)... like i said, i still burned a few holes, but it's my best progress yet.
    Hobart Handler 135
    Lathe/Mill/Bandsaw
    Mar 2008
    Baltimore, Maryland
    315
    I didn't do so well and the fumes were terrible. I need help. What amps and balance?
    James
    20Ton press
    Sep 2008
    Omaha, NE
    447
    Quote Originally Posted by StillBoostin View Post
    James
    I've used between 20 and 30 amps (with a tig start amperage of 10A and starting on EP) ..the better i get the more towards 30amps i stay. Balance is at 60% EN no matter what, I've used both 40-60hz range and up to right around 140-150 but it was more diffiult and required more torch manipulation. 40-60 was best. You must clean the cans REALLY good, you will see the oxide layer and something else come off and the metal will get shinier (not sure what all it is but scotch brite worked better than a wire brush) Start with the rod in the groove as soon as your arc strikes, then keep filling the puddle continuously while moving the puddle..dont' take the rod from the puddle at all!!!
    I've done it with and without the pulser...the settings i use on it are.
    30Amps
    15PPS
    80% peak
    10%background
    Using 1/16th tungsten (ceriated and thoriated) and 1/16 4043 filler rod.. I'm only burning holes when re-starting the puddle after turning the can to re-position for welding...a few weeks ago it was 3/16ths of sloppy bead and 1 1/2 inches of holes then another 1/8th bead LOL I put a pic of an older red-bull can i did about 2 weeks ago in my new thread in the project section
    Hobart Handler 135
    Lathe/Mill/Bandsaw
