Results 1 to 6 of 6
    Aug 2006
    woodstock ga
    33
    Default Is it designed that way
    look a these pictures, I have decided that the holes in that terminal were designed to store the bronze wire guides/tips. I have not found any reference in the owner’s manual as to the purpose of the holes. I do know that sometimes even the manufactures forget how well they make and design the products. I may be all wet but this works great and stores the tips. If Miller knows about these holes and this the purpose for them .............WELL DONE!
    add a note to the manuals
    Greg
    Aug 2006
    Suffield, Ohio
    344
    I don't know that is what it is ment to be used for, but if it works it works.
    Oct 2005
    Bulverde, Tx
    1,244
    I do believe dat is what dey are for.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Sep 2002
    Clark County, NV
    2,696
    I thought that's what the lip on the edge of the bottom pan was for, so the tips could just roll around the bottom of the wire compartment. Those holes must surely be for something else...
    Aug 2006
    woodstock ga
    33
    Quote Originally Posted by MAC702
    Well it pays to read the information (RTP, read the poop), I though I found something. it turns out IN the instruction (owners) PDF form it says Item #7
    ................................ TIP STOREGE ................duh!!!!!
    Greg
    Aug 2006
    near rochester NY
    9,881
    yep i keep a few there myself as last resort, i keep the big stock in a little case with the other gun parts but when the case runs out and i cant get to the LWS i use the ones in the welder and make shore i get the the LWS to restock.
