I am building some display racks for a customer and my metal supplier has problem with mill scale and i've tried just about every grinding and prep wheel. I was wondering what works good. Any input would be greatly appreciated.
Thanks mitch
Results 1 to 8 of 8
Thread: how to
Hybrid View
10-13-2005, 09:01 AM #1
- Oct 2005
- 8
how to
10-13-2005, 02:43 PM #2
- Sep 2005
- 10
I found that the rubbery sanding disc that kind of resembles a tuffy pad used with the rubber backing pad in my drill press seems to work pretty well for me. It definitely leaves marks on the metal though. I've heard the flapper discs work well, but I haven't personally used one.
-dath
10-13-2005, 04:18 PM #3
I built lots of display racks from HR flat bar. I use a Med flap wheel or 4 1/2" discs on my angle grinder. You will use a lot of them going to shiny metal...Bob
10-13-2005, 05:56 PM #4
- Sep 2005
- Vernon Ct
- 117
Try sandblasting. 90 psi with good grit does a great job.
10-13-2005, 07:41 PM #5
Member
- Sep 2005
- Syracuse N.Y.
- 60
Another option is to use cold rolled-no scale just some oil to clean.
10-13-2005, 08:17 PM #6
- Sep 2005
- 5
The easiest is to order your material P&O (pickled and oiled).
Methods for removing HR scale, other than grinding, include abrasive or shot blasting, and chemical pickling (generally acid or salt bath).
Some commercial products exist. I haven't tried this one myself, but it's been highly recommended. I don't know the price.
http://www.picklex.com/
