    Aug 2013
    New Brunswick Can
    42
    Thumbs up Need Help buying Sycrowave 250 dx
    Hi Folks I have the chance to buy a 250 DX( 16 hours on machine) it's equipped with a coolin system and one as new also with no cooler. But was wondering if cooling system would be a pain in the butt ,cause my shop(garage is not heated in winter) when not in use and here in Canada it can get cold as you know...
    What's your advice and thanks for reading.......AG
    Nov 2003
    3,584
    TIG coolant usually contains antifreeze...
    so your cold winters should not be a problem...
    http://store.cyberweld.com/lowconan.html
    life is much better with a water cooled torch...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Mar 2011
    st-eustache qc.canada
    243
    HTML Code:
    life is much better with a water cooled torch...Last edited by H80N; Today at 09:50 PM.
    LOL and a beer cooled torch holder...
    i envy you anticostiguide nice catch 250dx with 16 hours
    Aug 2013
    New Brunswick Can
    42
    The seller is asking 3800 firm....don't forget up here in Canada everything is aliitle more expensive than in the US....
    Thanks for the reply guys...more input the better. AG
    Nov 2003
    3,584
    Quote Originally Posted by anticostiguide View Post
    Seems a bit expensive... normally see them in the $2500 and below range here...
    but if it is exceptionally nice..?? maybe...
    could you post the serial number so we can tell you how old it is..??
    unlikely.... but it may still be under warrantee...
    On coolant.... if there are no warrantee issues... a lot of guys are running RV antifreeze.... it does NOT have the stop leak or other additives that most of the regular car/truck antifreeze has.... that tends to plug/clog torch body, pump and other tight passages..
    http://www.walmart.com/ip/Super-Tech...reeze/17179674
    My Blue Stuff:
    Aug 2013
    New Brunswick Can
    42
    Right on, will keep in mind.RV coolant is easy to get also...
    AG
    8,227
    RV coolant won't work, due to the alcohol content. Does it really get all that cold in New Brunswick anyways. Humidy yes, so lots of snow, but cold?
    Nov 2003
    3,584
    Thumbs up
    Cruizer
    you are right... the Walmart stuff NOW contains Alcohol...(ethanol/methanol)
    it never used to..
    they have changed the formulation..
    http://ops.americanamb.com/1101MSDS/...Antifreeze.pdf
    Many other brands of RV & Marine Antifreeze do not... so better to check the MSDS.. first
    the good ones are pretty much just Propylene Glycol and water,,
    http://www.midlandtool.com/MSDS/Peak...%20Coolant.pdf
    http://www.homedepot.com/catalog/pdf...df5e792462.pdf
    Thanks for the heads up..
    My Blue Stuff:
    Aug 2013
    New Brunswick Can
    42
    Cruizer it got down to -30 last winter, but usally it -25 c once in a while....but the cooled 250 dx is the answer in your opinion.....only issue it's 6 hours away....
    Thanks AG
