Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Aug 2008
    Orange, TX
    1,225
    I wouldn't throw in the towel just yet.
    Enjoy the vacation!
    BTW, if you can't find me here on the Miller sight, I spend most of my time over on WeldingWeb http://weldingweb.com/forumdisplay.p...&s=&daysprune=
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Oct 2007
    Cave Creek Az
    1,097
    FWIW, mine turned out to have a broken wire in one of the wires going down to the slip rings. The terminal in one of the molex connector cracked. Since the other wires were fine, that one stayed in there, but didnt excite the generator.
    Aug 2014
    16
    And your resistance reading between the center and front rings is a little low and should be 31ohms but the exciter rotor would be good at 12-12.5ohms.
    Had a minute this morning to check those out and I get 30.8 and 12.1 ohms.
  4. #14
    Aug 2014
    16
    Quote Originally Posted by walker View Post
    I hope mine turns out to be that easy (cheap fix). What reading, voltage or resistance, showed the problem?
  5. #15
    Quote Originally Posted by denwhit View Post
    Have power at the convenience plugs but no weld power.
    Just want to triple confirm, you do have the output contractor switch "ON" correct?
  6. #16
    Aug 2014
    16
    Quote Originally Posted by Can You Weld This For Me? View Post
    Both switches are in the up position.
  7. #17
    Oct 2007
    Cave Creek Az
    1,097
    While while testing, I bumped a wire and it sparked. Just pull apart your molex connectors to check for corrosion, and loose ones will make themselves apparent.
  8. #18
    Aug 2014
    16
    thanks for that
  9. #19
    Aug 2014
    16
    Default Fixed it!
    After getting good ohm readings across the diodes in the bridge rectifiers, yet getting screwy voltage readings, I just decided to replace them both. That worked! She's back to performing like a new one. I guess the lesson is that when the actual current hits those rectifiers, the real test begins. Anyway, my thanks to everyone who participated with help and advice.
