Results 1 to 4 of 4
    Apr 2013
    14
    Default miller tig contractor kit
    Miller has contractor kit (part # 301130) for their Multimatic 200 welder. It is compatible with their Dynasty 200 welder?
    They offer contractor kits (#195054 -foot pedal and #195055 - finger tip)
    How about the other way around?
    Lets say I get kit for Dynasty, will it fit/work with Multimatic?
    Thanks.
    Jun 2014
    Downey, CA
    98
    The Multimatic 200 uses 25-mm (small) Dinse-style gas thru for one-piece air-cooled torches., and a 6-pin plug for the foot control. The Dynasty uses the 50mm DINSE, external gas and a 14-pin plug.
    With the Dynasty kit, you need an adapter, 14-pin to 6-pin #300507 .... and, the proper DINSE adapter #195234 for the air-cooled torch.
    Glen
    Miller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45
    For Sale! - Hobart Handler 150 - Miller EconoTwin HF
    Apr 2013
    14
    thanks for the info. I guess I'll buy Dynasty kit with both adapters so I could use it down the road with new toy (Dynasty 200 DX) and current Multimatic 200.
    Thanks.
    Apr 2013
    14
    Back to same subject. If I get tig kit for multimatic 200, will it work with Dynasty DX 200 (assuming there are adaptors available)?
    After pricing it, kit for multimatic is cheaper
