Results 1 to 10 of 15
    Oct 2011
    24
    Default Large sheet butt weld on Aluminum
    First just learning to mig aluminum with Miller 211 and spool gun
    been playing a lot with settings and
    stuff. I have a goal of building a boat! 1/8" sheet
    will have all kinds of welds on it but the first may half to be a but weld on the bottom! About 56" long. The pieces are 8' long
    first how do you do it without it warping all over the place. And then
    in testing but welds I get lots of bead on the back of the
    plate I expect to have to weld both sides of it so am I welding to hot
    in the first place? Jumping back
    and forth with short arc and spray
    transfer at least what I consider it is.
    Along with this I get tons of burn through showing on the back of test plate
    what is the secret to not burning through so
    much. Thanks
    8,351
    1/8 plate you should really be using a pulse machine, with that unit your going to have to make alot of spot and short 1" welds with no more than 030 4043 wire, Argon at 15CFH, gun pushing at an angle to the work, NOT straight on, and ALL spray arc
    Aug 2012
    Hermiston Oregon
    298
    I weld aluminum all the time with this machine here are my settings. Wire speed is at 90-91 & temp set at 6. I also recommend swapping tips to the ones used on your mig gun . With 030 wire 4043
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Oswego IL
    818
    Quote Originally Posted by fishbum View Post
    much. Thanks
    Seems to me you bettar buy about 30 cans of flex seal because that boat is going to leak! Every time you stop and start is a very cold weld on aluminum, this is very bad on a boat. Also the stringers of the boat should be installed before seam welding the bottom. Making an aluminum boat from scratch is not an easy task, a pulse welder makes it much easier.
    kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    Cave Creek Az
    1,097
    Post up a pic of your design. Try to design, and build with as few pieces as possible, fewer seams. Grind your stops before you restart. If possible a different joint design rather than a butt weld. Try to incorporate structural stringers into the design as well, as this makes a good place to weld to without long butt welds. Look at commercial designs to see how theirs are made.
    Oct 2011
    24
    Default Boat
    Wow, guess I will opt for one piece bottom! Or just buy another hull.
    I have bought several from a small custom builder and I know they use pulse mig
    but can't see anyone doing 18' without stopping? Eecrvantes83. That seem real hot on your 211 settings. I'm still learning but right now I'm around 4.5 and 6 on wire. I guess I should ck forum for this but how the heck do you cut back the Cratering at end of weld! Thanks
    Mar 2011
    La
    330
    Building a boat with a 211 is limited in my opinion. Its a small hobbyist machine that lends itself more to small aluminum projects, however it can be done. I would compare it to framing up a house with a tack hammer compared to using a framing nailer or nail gun. Both get the job done, but you limit yourself with the underpowered option. You may not be satisfied with the end result, which may result in time and material wasted.
    However, good luck with your project and remember, you may be trusting your project with your life and the life of others who use it. Open up a seem in rough open water and your in trouble.
    If I would build a boat, I would purchase a pre-crimped hull and just finish the inside. Outcome would be safer and nicer and would still be a great project to enjoy building.
    Ja
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    Aug 2012
    Hermiston Oregon
    298
    The crater at the end of the weld is covered with at tack right after the weld bead is done . I mean in a split second.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Aug 2012
    Hermiston Oregon
    298
    This machine is no hobby welder under the right hands this machine can handle large difficult jobs easy. I'd post up pictures of some jobs and welds but my mobile app is giving me problems posting.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Oct 2011
    24
    Default Mig crater
    Quote Originally Posted by eecervantes83 View Post
    Thanks I will try that. Any video out there that showed that? Again the numbers
    you stated on your 211. 6 and 9 on wire are you on 120? Also what difference will I see again with 1/8 switching from
    .30 wire to .35. ? A guy I know built a boat for the first time and a miller rep had him change from .30 to .35. Had less trouble overall !
