Results 11 to 14 of 14
    Aug 2014
    5
    Default miller Bluestar 2e
    Nope , the Trailblazer 250G uses the same plate. however, there are none available after an extensive search. So you will likely have to get that one fixed
    I was directed to get a manuel but all I have is a serial number ja369806
    the website is asking me in addition to the serial number they want a model number I do not have one
    please assist.
    thanks
    8,350
    Just bypass all that stuff and click on bluestar 2e
    Sep 2009
    Canada
    198
    The bluestar 2E used a 16hp tecumpseh motor. Model OH 160
    The manual is downloadable on this web page and has a parts diagram/description in it.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Aug 2008
    Orange, TX
    1,223
    Default PN 021934 Adapter, fan-rotor
    Here's the manual http://www.millerwelds.com/om/o423e_mil.pdf for your unit and the part you need is the crank-to-fan/rotor adapter(PN 021934, item #70, page 4 of the parts breakdown.
    You definitely broke a piece that is rare today and if you can't get yours fixed shoot me a PM.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
