Results 1 to 8 of 8
    Default Thin walled Aluminum welding set up (Diversion 165)
    I am welding small bicycle frames for small kids. This is the setup that I started learning with. With constant struggles with my machine I decided I should reconsider my setup and what I am using.
    MACHINE:
    Miller Diversion 165
    CURRENTLY USING:
    Material: 6061 T6
    Wall Thickness: .049
    Tungsten: = 3/32" 1.5% Lanthanated (Gold Tip)
    Filler: 3/32 ER 5356
    What setup do you think would be best?
    Nov 2003
    3,328
    Thumbs up
    you may consider moving up to a Dynasty 200DX...
    with the added options of arc frequency, AC balance, waveform choice,.. pulse... etc...
    the ability to tailor your arc to help control bead shape and size is a big plus...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    I don't have any doubt about it. I really want to upgrade. Finally my ability to weld is not the weak link. I think I have about maximized this units abilities. You don't have one that you'd like to swap with do you? Even up?
    If it were not for money I would buy one.
    Nov 2003
    3,328
    Thumbs up 4943 Filler
    Keepin mine thanks...
    until you upgrade.. you might try a different filler...
    4943 is much more fluid than 5356 and might give you a bit better puddle/bead control with that machine...
    4943 is relatively new and it is pretty neat stuff..... might be worth a try..
    http://www.marinelink.com/news/paten...ces350264.aspx
    http://www.hobartbrothers.com/upload...Maxal_4943.pdf
    http://www.hobartbrothers.com/downlo...minumGuide.pdf
    http://www.millerwelds.com/resources...Casting-repair
    My Blue Stuff:
    1,883
    I would try using 1/16" filler. Having never used 4943 I would try 4043. I have heard good things about 4943 though.
    What exactly is the issue you are trying to overcome?
    Nov 2003
    3,328
    Smile
    4943 is a replacement for 4043 and a whole lot more...
    I would not waste my time with 4043...
    If you read the threads and links I posted.. you will get a better idea,,
    Then try the 4943 and see...
    My Blue Stuff:
    Dec 2010
    Sutton, MA
    36
    Keep practicing, mate. You'll get there. I run pretty much the same setup as you, except I have a Lincoln Square Wave TIG 175 and run 2% lanthanated tungsten. My machine is set to max (175 amps) and I work the pedal. The added features of a fancier machine would make life easier, but working with what you have for a while will help you appreciate them even more when you eventually upgrade. At least that's what I keep telling myself. These are 7005 tubes and I use 3/32" 5183 filler. But the concept is the same. Keep most of your heat on the headtubes and bottom brackets and wash the weld onto the main tube.
    AL001 by Zanconato Custom Cycles, on Flickr
    Jul 2006
    alaska
    181
    That is a 7000 series aluminum? strong stuff. Special order right?
