Results 1 to 2 of 2
    Jun 2014
    13
    Default Custom Headache Rack
    Hey, I have a friend who wants me to make a headache rack for his pickup truck. He also wants a winch mounting spot so he can pull his ATV into his bed. While looking at the picture he wanted me to base it on, it looked like the edges were made out of flat stock or sheet metal. Do you guys think that would be strong enough (not bend) to have the weight of an ATV against it?
    Jan 2014
    Idaho
    5
    I made one of these with the exact outcome in mind, what you may want to do is put flat stock that extends further across the end of the bed, about half way or so. It will spread some of the stress from pulling heavy things into the truck.
