Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
  1. #31
    Aug 2012
    Hermiston Oregon
    282
    One thing I didn't mention is that. It usually bogs down during my welding usually as I'm welding and it hasn't much while grinding.
    Ill look into. The 5" grinders but I love my makita 7" that thing is a beast at removing and cutting metal.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
  2. #32
    8,224
    Engine's getting too hot, so wrong oil, wrong oil filter, toss the green foam element off the air filter, Loosing vacumn to the vacumn fuel pump is all I can come up with right now (as engine is too hot). Perhaps its time to replace the fuel pump, as thats the first thing other than the rest of the stuff I'd be doing. The engine will load up to much if the high idle no load rpm isn't enough. Its a tough one but pretty easy to solve.
    Another culprit is the spark plugs usually the left one that likes to pile.
  3. #33
    Aug 2012
    Hermiston Oregon
    282
    Thank you cruizer I'm checking everything you mention. Hopefully solves the problem
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
  4. #34
    Oswego IL
    758
    Default what have u replaced.....
    Quote Originally Posted by eecervantes83 View Post
    First have you done your service to it? Service means engine oil and filter. FUEL filter, check and or replacement of air cleaned. Also replace the spark plugs. Now if that is done and you still have a probelm, after it boggs down does it restart easily, or do u have to crank, and crank? ...there are 3 possible probelms, bad oil pressure sensor(not likely as it would shut off instantly), bad/weak coil as i beleive it is, or fuel delievery probelm. If it is hard to restart, try pour a little gas in the carb, if it fires right up, you have a weak fuel pump, or a broken or leaking pickup tube. If it still does not start its a igntion coil.
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
  5. #35
    Aug 2008
    Orange, TX
    1,216
    Is it firing on both cylinders? Those Onans will run on one cylinder up to governed speed but lose it under load. They've been known to break a rod in one cylinder and keep on going.
    With it running, pull one plug wire at a time to see what happens. Use insulated pliers or welding gloves with pliers to keep from getting knocked on your can. If it keeps running with no change in speed/tone that cylinder is dead. If that's what happens, pulling the other wire after replacing the first should kill the engine.
    You could also just pull the plugs and check for compression while cranking it over.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
  6. #36
    Aug 2012
    Hermiston Oregon
    282
    Problem solved thanks to everyone who gave advice. Bottom line the machine needed a tuneup.
    Spark plugs were shoot . And oil looked dark but ok .oil filter had some really dark oil slush . No metal in oil found. It still pops the breakers tho.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
  7. #37
    8,224
    7" draws too much power, again no rig welders that I know of uses them. Had a feeling that the problem was tuneup related, score another on for me......lol
  8. #38
    Aug 2012
    Hermiston Oregon
    282
    Not yet cruizer. Still have the problem. It wants to shut off. I found a quick remedy if I pull the choke out it stays on and lets me work. But when I push the choke back in it dies. What's the deal.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
  9. #39
    Lodi, CA
    1,305
    Sounds like you have a vacuum leak somewhere. Either at the intake manifold or the fuel pump (vacuum hose or pump itself, they do go bad sometimes).
    Another thing, as you have an NT, I assume this is the old 90 degree flathead Onan. These do NOT have hydraulic lifters, they are mechanical, and need to be adjusted occasionally to compensate for wear. As Cruiser mentioned way back in this thread, if your RPM drops, voltage goes down and amperage goes up, thus tripping the breaker.
    If you happen to remove your intake manifold to replace gaskets, take a little time to remove the covers off the valve mechanisms, and set everything back to specs.
    I speak from experience, I've been dealing with Onans since the early 70's, when all Onans were still cast-iron blocks. Not welder power, but equipment power. Although they went to aluminum blocks in the 80's, they are still basically the same, and many of the problems are the same.
  10. #40
    8,224
    Actully quite common in the ONANS to pull the choke out slightly when running., still yes, best to adjust the tappets
