Results 11 to 12 of 12
    Aug 2009
    Ankeny, Iowa
    45
    Quote Originally Posted by JoeBarth View Post
    set to standard No difference with inpulse but lift arc works
    So now you have someplace to start. If you can get a TIG arc in Lift then maybe it's a switch issue. Sounds like a call Miller time.
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
    8,227
    You'll be able to lift arc without a remote plugged in, but without a remote, you won't be able to "impulse". So quite possible a failed remote., or the remote connector not wiggled all the way in as I see so many times on service calls.
