Results 1 to 10 of 12
    Aug 2014
    7
    Default maxstar 150 STH not tigging
    Stick welds ok. hf ok. No output on any setting. reset factory settings.
    Nov 2003
    3,846
    Question
    Quote Originally Posted by JoeBarth View Post
    Pedal..??...
    output setting on local?? or remote??.............
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Aug 2014
    7
    pedal is on it now. have finger control
    Nov 2003
    3,846
    Set to "Standard Trigger???
    See section 5-5 on page # 24
    http://www.millerwelds.com/om/o2242ac_mil.pdf
    Standard trigger
    Typically used with
    a remote amperage con-
    trol device. Standard trigger provides non-contact start in DC Im-
    pulse TIG mode. It also enables Lift-Arc start, with a remote control
    in Lift- Arc mode
    My Blue Stuff:
    Aug 2014
    7
    Thanks I'll give it a try
    8,351
    Tungsten type (NO PURE), what are you trying to tig?
    Aug 2009
    Ankeny, Iowa
    45
    Try it without the remote will it work then in the Lift Arc mode?
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
    Aug 2014
    7
    2% same as I always use. Just trying to get it to ark. Took a piece of steel, ground it clean. grounded good.
    Aug 2014
    7
    Quote Originally Posted by wmgeorge View Post
    I didn't think it did but I tried it to day and it did. on HF it sparks but still not welding
    Aug 2014
    7
    Standard trigger
    Typically used with
    in Lift- Arc mode
    set to standard No difference with inpulse but lift arc works
