    Oct 2011
    24
    Question Torch hookup issue Dialarc HF
    Bought a older Dialarc hf the other day has a water cooled tig torch
    that had a large fitting on gas hose. But machine has the small fittings
    like the size of the water like 3/8 or so. What has been changed?
    is there something missing? Will a different air tourch work? Thanks
    8,350
    Cause your missing the tig block
    Oct 2011
    24
    Default Tig block?
    What does it look like? Does it fit in one of the other fittings?
    thanks.
    8,350
    Tig block goes to your elecrode output stud, , fits the air cooled tig torch, and with a smaller hose going to your gas adaptor on your machine. You'll need a short chunk of gas hose with fittings as well
    Oct 2011
    24
    Default Tig block
    Oh ok, where can I find one
    8,350
    Local welder supply
    Oct 2011
    24
    Default Tig block
    Hate to be so dense but on the welder it has two large studs one on left says work! The other says electrode! Is work the ground? And electrode the tig where the tig block goes? And does the gas out connection go to the small side of the tig block? If so there must be a small jumper gas hose right? Thanks
    8,350
    Well you have a switch to reverse the polarity, however work clamp goes to the left, tig torch to the right, I mentioned you'll need a "short chunk of gas hose" for the machine and tig block.
    Oct 2011
    24
    Default Tig block
    Thanks.
