Results 1 to 3 of 3
Thread: cruizer
    Oct 2005
    North Central Indiana
    782
    Default cruizer
    Cruizer can I use these meters to check my MM251, 172 challenger, MM 180 and Syncro 180SD's compacitors? I'm finishing things up around the place and ready to check the machines out. thanks
    http://www.amazon.com/MESR100-AutoRa...ADHZJ1F17KMSYF
    http://www.amazon.com/Honeytek-A6013...acitance+meter
    8,224
    Not really, you asked how to get your machine running like new again, I told you. Checking each cap is a waste of time and money.
    Oct 2005
    782
    Thank you for the expert advice ....
    I just thought it would be interesting to learn how to check them out with a meter so I could check out the caps in my other welding machines which are old and not welding like they used to.
    I understand where your coming from and I thank you again...
