Results 11 to 15 of 15
    Dec 2013
    8
    Does anybody on here own one that wouldnt mind popping the cover off and posting a few pics of the proper layout? Im going to just wire it up myself cuz im 99.9 % sure of how it should be but really wana make sure before i do it. Looks like if i just leave the resistor ad the little black box ( limit switch i beleive it is called) in it and run the wires to those as the manual says it should work.
    8,281
    The diagram shows it pretty well, 2 on the micro switch in the normally open position (goes to the 2 pronger).
    and 3 on the vertical resistor, diagram shows the wiring to the plug
    Aug 2008
    Orange, TX
    1,216
    Quote Originally Posted by Dirtyd View Post
    Again, what you've got isn't factory and I suspect it was set up for some type of non-Miller machine.
    This one is an RFC-23GD25 but wired the same as an RFC-23A that would have a single section resistor rather than the 4 section shown.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Aug 2008
    Orange, TX
    1,216
    Here's what the RFC-23A looks like.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Dec 2013
    8
    Wow thats exactly what i thought thanks for the pic now i know exactly what to do. Gona order the two plugs for the cords tomorow then i can get it going thanks!
