Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Smooth welds??
  1. #21
    NY
    99
    Quote Originally Posted by Portable Welder:322385
    MMW and Trygn5 are right, There is nothing wrong with smooth, Rippled welds are caused by peddle manipulation and dipping the filler rod.
    Smooth welds are caused by smooth even power, a steady hand and a steady feed of wire.
    The nice thing about a smooth welds are that it makes it easier to detect if you have any under cut at the edge of the weld.
    The nice thing about pulsing which will give you a rippled weld is that you get a little less heat input into the part, in some instances this is good and other times you want good heat input on say thick heavy weldments for good penetration.
    10/4 on that brother. Theres a time and place for every method. I run smoothe alot as well. Depends on what ya need.
  2. #22
    Quote Originally Posted by WickedWrenches View Post
    Have a Diversion 180. Using 1/16th 2% ceriated with argon set to 15cfh, 3/32 Er70s-2 filler rod at 75 amps. Doing practice lines on clean 16 gauge mild steel coupons . Im keeping a slow steady constant speed across the steel while welding and the welds are coming out smooth, no ripples in some sections. Even if i use stop and go or move forward then back a little in small increments it still stays smooth, Im holding the torch at 70 degrees as recommended and pushing the puddle, not dragging it...cant seem to get steady ripples, am I doing something wrong here?
    Attachment 34367
    Hey! A little late! Haven't been here for a while. Your weld looks like you are running too cold. The amps you are running are good. The problem is your filler is thicker than your base material. When you add rod, you are sucking the heat out of the puddle. Then your filler just piles up on top. Hope this helps.
  3. #23
    Sep 2009
    South Carolina
    571
    Quote Originally Posted by kelsart72 View Post
    I'm no expert but your pic looks like you're moving too fast and not getting enough of the filler wire in the weld, i use a tapping motion when i TIG weld, tapping the wire into the heat while steadily moving forward and not just pushing the wire into it, I hope that makes sense and helps.
    Makes sense to me. Lately my practice has been doing this with the tip of the filler just tapping into the puddle right before the tungsten hits it.
    Everything stays close but it melts the rod back just in time to raise out and tap again. I also believe in sliding the torch hand and not bending at the wrist. Get longer straighter welds.
    Hold that filler in a perfect line with where your going, helps keep straight.
    I've also started keeping focus on the filler tip and tungsten tip after the puddle and heat is established , the puddle just comes along in the background as you focus is where your moving too and the tip of the filler.
  4. #24
    Jun 2009
    las vegas
    227
    Sorry mention to say not always a bad thing sorry for the confusion
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
