Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Smooth welds??
    Angry Smooth welds??
    Have a Diversion 180. Using 1/16th 2% ceriated with argon set to 15cfh, 3/32 Er70s-2 filler rod at 75 amps. Doing practice lines on clean 16 gauge mild steel coupons . Im keeping a slow steady constant speed across the steel while welding and the welds are coming out smooth, no ripples in some sections. Even if i use stop and go or move forward then back a little in small increments it still stays smooth, Im holding the torch at 70 degrees as recommended and pushing the puddle, not dragging it...cant seem to get steady ripples, am I doing something wrong here?
    Dec 2013
    Clovis, NM
    44
    I'm sorry, I personally have no idea, but i'm willing to bet that the pros on here will want pics and I'd like to see as well.
    Try to do some flat welds without using filler. When using filler use as little as possible.
    Aug 2009
    Ankeny, Iowa
    45
    I've never been able to run a bead with TIG without filler?? I can do a lap or corner weld without filler. It takes a lot of practice be become good at TIG welding and maybe years to be as good as the guys on here.
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
    Do a butt joint. Tac both ends and then add some small tacs. Depending on how long the piece is say 7" put tacs 1" apart. Then weld from one end to the other. This will help keep the piece from warping. Also don't overheat the piece stop and take a break.
    NY
    99
    I like to manually pulse the pedal while im feeding. Helps with wetting out and consistency.
    1,897
    Do you have a foot peddle or hand control? Just because the machine is set for 75 amps doesn't mean you are at 75 amps unless the control is full on.
    Try using thinner rods. 1/16 or even .035". This will allow you to use a little less heat & dab the rod into the leading edge of the puddle, don't just move it steady with the torch. I know everyone loves the look of stacked dimes it isn't always the best weld. Not saying it's bad, it's just that you can have a very good weld without it.
    Jun 2009
    las vegas
    227
    Default Smooth welds??
    Dabbing that filler or pulsing manually as previously posted should fix that prob. But smooth is always a bad thing.
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    1,897
    Quote Originally Posted by strictlycarved View Post
    I disagree with the smooth is always a bad thing comment. You can have a very good, structurally strong weld with it being smooth. Somewhere along the way the rumor got started that the only weld that's good is a stack of dimes.
