Results 1 to 10 of 14
    Jul 2014
    Default Bronze statue repair
    I own a bronze statue of St George slaying a dragon. I believe it was inherited by my grandfather. When it was shipped to him the front legs of the horse were broken off at the knees. My question is, can it be repaired, and how. Some of the metal from the knees is missing and would have to be filled in.
    i am located in Ohio. Would need someone in driving distance who could do the repair.
    Try to get a hold of aametalmaster. I believe he is in Ohio and maybe he can help you.
    3,954
    Quote Originally Posted by JMK WELDING View Post
    I am in Salem right below Youngstown if that helps...Bob
    Sep 2009
    Colorado
    230
    Quote Originally Posted by Printydm View Post
    One challenge is the unknown material. If it was cast in silicon bronze, that is easy, but other alloys may or may not be easy to weld. Some may choose to solder instead.
    Best to have someone with experience repairing old statues. Even though I am a metal sculptor I would not be comfortable taking the job.
    Richard
    Aug 2004
    Milan Michigan
    1,863
    I would start out with silicon bronze.
    3,954
    I have 40 lbs of it on hand...Bob
    Bob the reason I said he should contact you is because I knew you were in Ohio. I've seen some of your pictures on the Miller website for projects way before the forum came about. Nice work. JOE
    3,954
    Thats fine. If i can help i am here...Bob
    Oct 2005
    North Central Indiana
    782
    Just a suggestion but how about using a jewlers torch and Brownells hi-force-44-trade-solder. The piece can be airbrushed to make the repaired joints disappear.
    http://www.brownells.com/gunsmith-to...r-prod709.aspx
    Aug 2009
    Ankeny, Iowa
    45
    Quote Originally Posted by tackit View Post
    Find a Heating and Cooling wholesale house, $110 for a 1 lb roll is about 3x what we paid. Good stuff and very strong.
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
