Results 1 to 8 of 8
    May 2011
    North Carolina
    8
    Default Millermatic 200 no welding current
    NOW FIXED! See last post
    Hi, while welding, suddenly I was not able to get an arc. I can get a small sparks on both low and high voltage settings, but no current. Also, the Transformer hum slowly goes away when trying to strike.
    Check connections, cleaned ground clamp, cleaned gun, and then searched forums.
    Someone else had the same problem in 2011, although his solution was a gun fault ... this doesn't seem to be that. I did do the drive to ground check recommended in that post, and I get 15-16v (low voltage) setting when operating the gun and striking the arc (reading does not change when striking). Same on the high setting except voltage is 29+ volts.
    Feed motor runs, the contactor closes, and gas valve opens.
    It is a really old unit, and I cannot find a serial number. I have posted a photo in case it helps!
    Cave Creek Az
    1,080
    If you ar getting voltage from the lug on the drive roll to the work clamp, but no voltag from the work clamp to the end of the gun you have a gun that the cable had pulled out of. Get a new gun.
    8,350
    Open it up, likely have a busted winding going to your output studs. Just have to yank on it, drill it and stuff it back on, unless it damaged the output stud, in which case you can get another, or Magiver it.
    May 2011
    North Carolina
    8
    Haven't checked the gun voltage yet ... will do so tomorrow.
    Quote Originally Posted by walker View Post
    May 2011
    North Carolina
    8
    Default Gun problems?
    Checked the voltage from the welding wire exiting the gun to ground, shows 29V.
    I vaguely remember that the gun felt hot after I stopped welding, prior to it not working, so took the gun apart ... It looked like the insulation had melted and only a couple of the braided wires were attached (see last image below).
    Any suggestions on how to re-attached the wires? Do I clean everything up, feed them through the rearmost collar, and then tighten the collar onto the nozzle?
    Nov 2003
    3,725
    Thumbs up
    Quote Originally Posted by atgordon View Post
    This looks like a fine time to invest in a new gun....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    May 2011
    North Carolina
    8
    Default FIXED! Gun repair complete
    It was the gun, and since the welder has an optional GA-40 and non-conventional twist lock fitting, I really didn't want to go down the path of a new gun ...
    So ... found a GA-40C manual online:
    • cut off clamp ring holding the cable connector to the sleeve
    • removed the cable connector assembly
    • cut braided cables back to clean wire, all the same length
    • cut plastic sleeve back to ensure that the cables were clamped on the tapered part of the connector
    • slipped new clamp ring on sleeve
    • push assembled connector into sleeve
    • crimped new clamp ring
    • fed braided cables through clamp ring (spread them out over 360 deg)
    • clamped cable against cable connector by tightening clamp ring on the cable connector
    • reassembled gun
    Bingo .. welding like a champ!
    Appreciate the advice given (and the previous posts on this topic). Seems like the gun is the weakest link, and the most prone to fail!
    Aug 2009
    Ankeny, Iowa
    45
    • reassembled gun
    Good job and you were smart enough to cut back the wire until it was no longer heat damaged and I assume you cleaned up the barrel area nice and shiny.
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
