Results 1 to 10 of 11
    Question Tig welding mild steal, weld cracking.
    I just got a Diversion 180. Been doing lots of practice welds in straight lines on 1/8" angle iron cut from bed frames. Im use 2% thoriated 3/32 tungsten, argon set to 15 cfh, 3/32 ER70S-2 filler rod and amps set to the recommended 75 amps on the chart for metal thickness. Welds look uniform and getting penetration but Im getting small cracks riding down the center line of the weld, not along the edges, but directly in the middle running the length of the weld. Does the same thing with 1/16 2% tungsten with all the same settings. If I set to less amps, say 50, it doesn't do it but its under the recommended setting and doesn't get full penetration. How do I prevent the cracking or am I doing/using something wrong?
    Nov 2003
    3,565
    Smile
    Quote Originally Posted by WickedWrenches View Post
    Bed frames are VERY high carbon content and are crap to weld...
    and will be prone to cracking... just like some tool steels..
    try some other metal... bet you get better results...
    BTW... you don't want to use Thoriated with an inverter like the Diversion...
    you will be happier with some 2% LANTHANATED...
    Here is a Tungsten Guidebook you might find informative...
    http://www.diamondground.com/TungstenGuidebook2013.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Thank you for your input, Ill grab new tungsten tomorrow and some different steel.
    Wa
    632
    Is the material painted?
    Was painted, I stripped it of all paint to bare metal with a wire wheel and wiped it clean with acetone.
    Wa
    632
    You probably need to do more than just wire wheel. Actually flap disk or grind to fresh metal. Then hit it with a-tone.
    I just ran a bead on a different piece of steel and again on the bed frame steel. Only the bed frame steel cracked, and the other did not under the same settings. Now I know not to use angle iron from a bed frame for anything do to structural concerns for any home projects. Something new I learned today..Thanks!
    Lake of the Ozarks MO
    3,593
    You can use it all you want. Just don't expect it to weld good.
    Plenty of things made out of bed frames that do just fine.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Nov 2003
    3,565
    Thumbs up
    +1......
    You do not want it in critical structural places...
    it is spring tempered because of the bouncing nature of bed frames...
    So the metallurgy gets all goofed up along the HAZ when heated and welded...
    This is why you often see cutting tools or spring steels joined by brazing or silver solder.. that require much lower temps..
    My Blue Stuff:
    Houston, TX
    900
    I have lost count of all the welder carts and other items I have made from bed frames. Not easy to weld or cut, but works fine, and often the existing holes are functional.
