Results 1 to 1 of 1
    May 2008
    Troy, MI
    350
    Default Mower deck front bracket looked like it was attacked by an axe
    A CNC machine repair man from the shop brought in a broken bracket to be welded, which supported the mower deck of his lawn tractor. The bracket had gash marks on it that looked like it was removed using an axe. It turned out the bracket fell off during operation and the mower deck with the blades spinning ran it over. I am thinking that the blades actually chopped through the 1/2 " diameter bracket -- Impressive.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Miller Spectrum 375 Plasma Torch
