Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Jul 2014
    13
    Exclamation
    Quote Originally Posted by duaneb55 View Post
    Then check for a failed SR1.
    My guess would be one side is bad.
    SR1. I'll dig in my manual, find it and order it. I appreciate the help very much. Thank you.
  2. #22
    Aug 2008
    Orange, TX
    1,216
    I said it would be my guess that it's bad but I would still test it first before buying a new one.
    Don't just be a parts changer but figure out what's wrong and replace/fix only what's necessary.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
  3. #23
    Jul 2014
    13
    I understand Duane. I probably just need to take it somewhere as I'm not an electrician at all. I can change parts, but electrical troubleshooting isn't my strong point. SR1 was just a $10 part so I went ahead and bought one. Problem is, when I got it the tang configuration is different than the OEM original on the machine. The original has 4 tangs all coming out from the body of the SR1 in the same configuration. However the new one has 3 facing the same direction and 1 twisted sideways. Not sure which wire goes to which tang.
  4. #24
    8,281
    The exsisting one will have a knotch, thats positive, the new one with the tang not like the others is positive (should say on the side of the bridge anyways) so diagnol to it is neg, (X pattern)and with the other 2 being the AC inputs.
  5. #25
    Aug 2008
    Orange, TX
    1,216
    What cruizer said and/or the tangs may be stamped with their IDs (+, AC, -, AC) as well.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
  6. #26
    Jul 2014
    13
    Default Mega Thanks to Duane and Cruizer
    I want to tell you two guys (Duane and Cruizer) that I owe you a beer if you get in the Waco Texas area. You guys just saved me a ton of money. The SR1, once I got it hooked up right, worked like a champ. The ol' Blue Star 2e is humming and arcing like a new one. I really appreciate your help and assistance. Thank you both.
