Results 11 to 20 of 26
    Jul 2014
    13
    Quote Originally Posted by josh birkhead welding View Post
    Not trying to be smart But have you made sure it is in weld mode and not power. Reason I ask is because it happened to me .
    Thanks for the tip. Yes I double checked. It's definitely in "Weld" mode.
    Jul 2014
    13
    Default Stumped everyone
    Quote Originally Posted by jrgrtx View Post
    Good evening everyone. I'm hoping to get a little help on a problem with an old Blue Star 2E. Put on a new battery this weekend but I must not have tightened the positive cable enough. When I went to crank it, the cable sparked at the battery connection. I tightened it, cranked it, and went to strike an arc, but nothing. It just sparks a little but not enough to even stick the rod. Battery is brand new and fully charged. Idle doesn't rev up when trying to strike an arc. Any suggestions on where to start? Thanks to everyone in advance.
    Well, looks like I stumped everyone. Ok. Next question. Anyone know of a good repair shop in the Dallas, Fort Worth, Waco areas?
    8,227
    I don't see it written here, but do you have 120 auxillary power?
    Say for a grinder
    Jul 2014
    13
    Say for a grinder
    There is a 118v outlet (can use while welding) along with the other normal 110 generator outlet.
    8,227
    I know what the unit has,,,,,,,. what I want to know is if they work??
    Aug 2008
    Orange, TX
    1,216
    Possibly a bad WELD/POWER switch (not making contact in WELD position).
    Do you have AC voltage at bridge rectifier SR1 AC input terminals in WELD mode?
    If no auxiliary power output in POWER mode, SR1 may be bad.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Aug 2008
    Orange, TX
    1,216
    Default Miller Service Facility
    If you still feel you need a Miller service facility in the DFW/Waco area . . .
    Larry Burross
    Applied Equipment, Inc.
    2515 Cartwright St.
    Dallas, TX 75212
    214-630-9353 phone
    214-630-9354 fax
    888-630-9353 toll-free
    214-577-9353 cell
    Email: weldersales@airmail.net
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Jul 2014
    13
    Sorry Cruzer. misunderstood what you were asking. Yes, the plug works but it's very weak. Grinder turns about half speed when plugged in there vs. full speed when plugged into the generator 110 outlet.
    Jul 2014
    13
    Quote Originally Posted by duaneb55 View Post
    Thank you sir. Yes, I have aux power but it's very weak. With a grinder hooked up, it turns about 1/2 speed.
    Aug 2008
    Orange, TX
    1,216
    Then check for a failed SR1.
    My guess would be one side is bad.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
