Results 1 to 8 of 8
    Jul 2014
    4
    Default chain cup holder of fail
    I had some chain and wanted to make something out of it after seeing the chain wine bottle holder in another thread. I imagined a johnny-5 hand from the movie short circuit holding a coke can.
    This is the first time I've welded chain but I thought "that looks easy enough", lol and boy was I wrong.
    It was like pulling teeth trying to get it to stay in place while welding it.
    The chain I used was cheap and each link started pulling apart as the metal was heated and cooled so I had to weld each individual link together.
    The chain was 3ft long....well I needed 4ft so I cut some of the welds and did a different design...and still needed another foot, doh.
    I couldn't get a good ground because the links would move breaking ground. So I turned up the heat to try and get it tacked but it just blew some links in half, double doh.
    Anyway here it is
    Dec 2010
    383
    such a nice cup holder it seems you left everyone in the forum speachless.
    Jul 2014
    4
    everyone must already have a pretty snazzy cup holder
    2,968
    Looks like galvy plated chain= PIA to weld
    need to remove the galvy- mucho easier to weld.
    Or find weldable chain
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by grndamgt4 View Post
    Not a cup holder, but I do have a lamp.
    http://www.millerwelds.com/resources...ght=Chain+lamp
    Don't know as I need a cup holder, as I have one built in on the end of each arm.
    May 2012
    110
    hey i dig it! spray it with black grill paint.
    try some bigger/thicker chain next time! then you can have it hold a 5 gal water dispenser container! put a petcock on the bottom of the jug and ........ there you go! lol
    Miller Thunderbolt 225 AC/DC
    Millermatic 211 Auto/MVP
    Cave Creek Az
    1,097
    Next time, put the welds on the bottoms of the links, where they cant be seen.
    Jul 2014
    4
    Hey nice work on the lamp, I had seen it before doing the cup holder but the misses said no .
    Also that would be one sweet water cooler.
Tags for this Thread
