Results 1 to 10 of 13
    Default TIG Welding a tight area.
    I have a Diversion 165 welder and looking to expand my knowledge/capability. You guy's always level me up. I can't get my cup insider here to weld it like I would like. How do you recommend I weld this bead? It is OK if the weld goes onto the third tube.
    I know I need to change my cup size. But what other parameters need to change and what can I expect?
    6061 Aluminum 0.035 wall (thin!)
    currently I have a #7 cup.
    Mar 2011
    La
    300
    Quote Originally Posted by ggodwin View Post
    A gas lens with a longer tungsten stick out may be helpful.
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    Jun 2012
    Tracy, CA
    221
    Longer stickout. Increase shielding gas flow a bit for the longer stickout. I would attack it from the sides. No need to weld straight down.
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Should I start the bead in the deepest of the tight spots?
    Mar 2011
    La
    300
    I would weld into or toward the deepest spot, the additional heat input may help the flow of material into that area.
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    40 ton press brake
    Houston, TX
    900
    This set would help you. BTW, they are CK Worldwide, not junk.
    http://www.ebay.com/itm/Stubby-Gas-L...item20dab56630
    Cave Creek Az
    1,055
    Maybe a plain cup might get you further in there as well, try a 6.
    gas lens + aluminum foil dam so you can get the stick out that you need, or this
    CK Micro Tig Torch
    HTP Invertig221 D.V. Water-cooled
    Eastwood MIG175 w/spoolgun
    Eastwood Versacut40 Plasma cutter
    Aug 2004
    Milan Michigan
    1,834
    Since both tubes need to be welded you can bring the weld up higher onto the tubes as they spread far enough apart to allow the cup to get in.
    Dec 2010
    Sutton, MA
    38
    Yes, the bead can flow onto the third tube. Just make sure you aren't just bridging the gap. Don't be afraid of a bigger fillet. As Oscar said, a foil dam is a great tool. I use them a lot, especially when working with titanium. With that joint, I'd run a gas lens, #8 cup, and about 18-20 CFH. That should suffice to get the coverage you'll need with the additional stickout.
    Trying out a Dynasty by Zanconato Custom Cycles, on Flickr
