    May 2008
    Troy, MI
    354
    Default Mower Deck Repair
    After I removed the bubbled paint you could see that the mower deck rusted away near the front support bracket. I'm not sure this applies here but in the past I have seen metal rust faster in high stress areas. I used a cut off wheel to remove the weld that attached the bracket to the rusted mower deck and to cut a slot to make room for my patch. I MIG welded the patch.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    354
    And here are the last two pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Jul 2009
    Australia
    1,031
    Hi
    I know it is not structural but that is a bit of spatter you got there.
    May be your machine needs adjustment.
    Ji
    Grip it and Rip it
    Nov 2009
    houston pa
    104
    Nice one Don.
    Can I have your lathe?
    May 2008
    Troy, MI
    354
    Quote Originally Posted by Jigantor View Post
    Hi
    Ji
    I welded a little bead of spatter on the end of the contact tip.
    When I removed it I think that I bent and distorted the tip so that it didn't feed the wire properly. I believe that this caused the excessive spatter. Thanks for bringing this to my attention. I will replace the contact tip.
    Quote Originally Posted by mikecwik View Post
    Nice one Don.
    Thanks, Attached are some pictures of last night's project.
    The rod is .1516" OD, had a .001" OD tolerance and was 2.125" long.
    I like to use the drill chuck on the cross slide for fine work like this because I can dial it in by using the knurled nut on the QD tool post for up and down the cross slide for side to side and the compound rest for the angle.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
