Results 1 to 7 of 7
    Jun 2014
    Default millermatic 200 stoped working woes
    I've have had a millermatic 200 serial #jd7322347 since buyin it new. Great machine, but has now developed a problem.
    I was welding tacks and when I let off the trigger the wire stuck, no problem except this time I had to cut the wire.
    Everything works,fan feder,gas flow, but NO WELDING POWER. I do get a small spark when I pull trigger but no welding power.
    I would like to ba able to fix it myself verses hauling it 30miles and payin.
    HELP. Doug
    Aug 2009
    Ankeny, Iowa
    45
    Its still in warranty correct? I think a phone call to Miller would be in order if you haven't already done so. I'd think some sort of reset would be the answer.
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
    Wa
    628
    I don't think it's possible for a 200 to have a warranty. There has been two successors to it now...
    Aug 2009
    Ankeny, Iowa
    45
    Oops my bad, thought it was a Multimatic 200.
    Does the contractor click in? Wire feed motor run?
    Retired
    Master Electrician
    Nov 2003
    3,508
    Quote Originally Posted by izzydog View Post
    HELP. Doug
    With that serial number it is a 20 year old unit... (Not too bad an interval before it needed service..)
    can you hear the contactor "CLUNK"...?? when you pull the trigger..??
    there are a whole bunch of MM200 troubleshooting threads.. that are worth searching and reading...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oklahoma Indian Land
    23
    HELP. Doug
    Diagnosis...
    Machine ON, pull gun trigger feed wire out 2", set wire speed to "0". Get an ohm meter set it to voltage, connect + to gun and - to ground, pull trigger on gun and read voltage. With machine power set to 6 on the control you should have a reading around 26 volts on the wire. If not the rectifier bridge is bad most likely. It is located in the top of the machine about mid way, it has 4 wires and is held in place with 1 screw in the center. what ever you do don't mix the wires up when changing, change them one at a time. Just my best guess
    Cave Creek Az
    1,048
    Most likely is not a rectifier bridge. Most likely is contactor points burned, then female connectors burned, then some other stuff, then rectifier. Start with the cheap, easy, and common problems first.
