    Jun 2014
    3
    Talking Miller Dynasty 200 reads 0.0 on voltage meter in stick mode after doing factory reset
    Will not stick weld in stick mode AC or DC and has 0.0 on volt meter the only mode volt meter shows voltage is in tig-lift
    Oklahoma
    743
    Quote Originally Posted by jimbobrat44 View Post
    More info needed.
    Griff
    8,351
    When you open it up are the single phase back and white primary on 1 & 2 left to right black and white, orrrr?
    Jun 2014
    3
    Yes black 1 WHITE 2 IT WAS WORKING FINE THEN DID A FACTORY RESET AND AFTER THAT IT VOLTAGE STARTED READING 0.0 VOLTS AND WILL NOT DO ANYTHING
Tags for this Thread
