Thread: Millermatic 130
    Jun 2014
    Default Millermatic 130
    Hello all,
    I have a miller 130 that I can only weld with the voltage set on 3 or 4 because the welder only feeds wire if the feed speed is set at 80 or higher. I opened the cover and verified the spool doesn't turn at all at any speed below 80. Any ideas on what this could be?
    May 2011
    Bossier Parish La.
    560
    You may need to adjust/tighten the tension on your drive rollers. The rollers may need to be cleaned first.
    Jun 2014
    Nothing turns until the speed dial hits 80 even the feed rollers. I believe something is wrong with the control board.
    Dec 2011
    8
    Default mm 130
    Need a serial number (age). Miller made different versions of this. One was a 130 auto arc, and had no handle, the other, has a carrying handle on top. Which do you have?
