Results 1 to 10 of 14
Hybrid View
    Jun 2014
    2
    Default What size wire for 220 circuit for Miller 211
    I'm getting the miller 211 and I need to wire in a 220 outlet for it. I need to know what size wire to use. Its about a 50' run Thanks
    Feb 2012
    Wa
    671
    This has been discussed many times. You will find lots of info by searching.
    Sep 2009
    Colorado
    238
    Default Manual
    Quote Originally Posted by ehofer1 View Post
    The manual should answer that question. It can be downloaded from the resources link at the top of the page.
    Richard
    Jan 2014
    Northern West Virginia
    37
    8 AWG with a 40 amp breaker because the machine draws almost 30 amps.
    4,513
    The manual is confusing at best. Ignore the 14 and 30,,, with a wire 12 or better you can breaker this machine to 50A,,, but my tailor made circuit for one is 10/30.
    Apr 2013
    metro Detroit
    95
    I ran mine off of 75' 8 gage wire and a 40 amp breaker. I think the book called for a 50 amp breaker
    Houston, TX
    900
    Quote Originally Posted by bigtow30t View Post
    My MM210 only calls for a 40 amp breaker.
    Oct 2006
    Illinois
    661
    I would run #6. That way when you upgrade you will have large enough wire. Price the difference between # 6 and 8
    Jun 2014
    8
    I don't believe #12 wire should be on a 50 amp breaker, and I don't think it's good for over 20 amp breaker but not sure.
    I just wired mine with #8 as I will probably get get something bigger down the road.
    Breaking the above mentioned rule, I did wire a 110 outlet onto one of the legs in the box so I don't have to run and additional ext. chord for the grinders.
    Los Angeles
    2,971
    Quote Originally Posted by Castiron View Post
    It's muddy for sure on this BUT it is allowable under certain circumstances.
    Even the Miller manual has 14g wire on a 30amp as minimum wiring if you follow the NEC art 630 guidelines.
    As Sberry mentioned the manual causes lots of confusion- that's why he stated 10g 30amp is a really good fit. Doesn't break the bank on wire costs and easy to work with.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
