Results 11 to 20 of 20
    May 2014
    15
    Rainy afternoon so the kids didn't have softball or baseball games and I finally got a chance to play metal shop for a couple hours. I'm going to try to build a domed lid for the fire pit. I will be using 1/8" x 2" flat steel for the frame and lining it with expanded metal. I build a jig using 3/4" plywood cut to the approximate shape that I want the base to be. I then bent some of the flat steel around the frame. Since steel has a memory, I used a piece of C channel as an "anvil" of sorts to round the steel into the shape that I wanted.
    May 2014
    15
    After getting the ends bent to my satisfaction, I had to cut a few filler pieces to make the hoop the overall length that I needed. I welded the four pieces of steel together and had my hoop. A bit of tweaking/stretching with my hands and feet got the hoop adjusted to fit around the pit.
    May 2014
    15
    After I had the hoop welded up and looking ok, I went back to the bending jig and bent a couple more piece to be the arch of the lid. Once those were bent and pretty similar in shape, I welded them to the hoop. Then it was dinner time and time to get the kids to bed so I'll be revisiting this project as soon as I can.
    Once again, if anyone has suggestions to improve what I'm doing, please throw them out there.
    May 2014
    15
    I got a couple hours yesterday and today to work on my fire pit. I ground the welds on the dome and installed a couple pieces of 9 gauge expanded metal. It was a bit of a challenge to form. I cut the pieces with an angle grinder and cutoff wheel. I then clamped one edge to the side of one of the propane tank halves. I beat the metal with a sledge hammer and ball peen hammer to the approximate curve of the tank which wasn't quite enough for the dome. To get the metal closer to the shape of the dome, I used a piece of scrap C channel and beat the metal between the edges of that to gradually get the curve closer to the dome shape.
    After I got close, I used vise grips and welding clamps to hold the expanded metal to the dome and welded. It was more of a challenge than I thought it would be to weld the expanded metal. It was kind of tedious.
    Lesson of the weekend came from my aching back...first project should have been to build a tall welding table/workbench. I'm about 6'2" so I typically build all of my workbenches higher than normal to save my back.
    Jul 2014
    3
    i would never put a unknown propane tank in a fire. the safest way to make sure you can cut a propane tank is to shoot it from a distance. ive done it before. and no it wont explode.... if you want it to explode you have to cover it in gas, light it on fire and then shoot it from a distance.
    cool project btw
    May 2014
    15
    It wasn't really unknown. I had taken the gauge out which left a hole without a feed tube etc. I then turned it upside down for about 2-3 weeks with that hole facing down. I probably didn't need to burn it in the brush fire but thought it would be a good additional step.
    May 2014
    15
    Default Update
    I got a chance to finish the top to my fire pit this afternoon. It isn't perfect, but I'm satisfied with it at this point since it's the first project I've attempted with steel and welding.
    Bending the expanded steel into the corner pieces was pretty tricky. Took lots of hammer swinging, clamping and patience.
    May 2014
    15
    I got a little time today to work on my fire pit. I had to build a couple jigs to bend the rod for the foot rest and to get it held together in a hoop before welding it to the pit.
    After I got it tacked together in the hoop configuration, I cut a hole in the middle of the jig to allow me to drop the pit into the middle and set the foot rest 3/4" below the top edge of the pit. After cutting each of the small attachment pieces to fit, I welded the hoop to the fire pit.
    The hinges that I made to attach the top to the pit didn't work as well as I had hoped. It will work, but I may grind them off and try something else.
    I still need to:
    1) cut holes/install pipe or something in the bottom to let it breathe
    2) cut a drain hole or two so it doesn't fill up with water
    3) make a handle to lift the top
    4) wire brush the rust off the pit and paint the whole thing with high heat paint.
    May 2014
    15
    Finally completed the fire pit this weekend. After making a handle, installing some air inlets and drilling a drain hole; I painted the whole thing with Rust Oleum high heat black paint.
    May 2008
    Troy, MI
    361
    It looks great and is a job well done.
    Hopefully you are now hooked on welding like the rest of us.
    Don
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
