Results 21 to 30 of 34
  1. #21
    Just got back.
    Bought a brass ground but had trouble finding lanthanated Tungsten.
    Went to 2 weld shops...no luck.
  2. #22
    also... had you checked and tightened cable connections as Cruizer had suggested??
    I'm about to put the Miller power cord back on and check the points so all connections will be checked.
    ANOTHER approach you might think about is to sell the Dynasty you have and invest in a new one...
    it really depends on if your budget will allow... and if you wish to bypass the learning curve/grief of arc starts on the older one... probably have no problem selling it
    or even find a newer "Blue Lightning" equipped one on the used market...
    (Dynasty 200 with a serial# of LJ280222L and above are equipped with "Blue Lightning")
    And you could go directly to working on the car...
    I like this idea...this may be to much machine for me anyway.
    I paid $1500 for the entire set-up with gas and a bunch of extra stuff. You have any idea of what it might fetch?
  3. #23
    Nov 2003
    3,419
    Smile
    Quote Originally Posted by scratchedup View Post
    Just got back.
    This is the easy answer for 2% Lanthanated...
    http://www.ebay.com/itm/10-HTP-2-Lan...#ht_841wt_1106
    and your arc starts will probably improve as well...
    there are several decent suppliers on fleabay/or internet..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
  4. #24
    Nov 2003
    3,419
    Would think you could get $1500-2000 for the bare power supply.. but others might have a better handle on used prices...
    would do some more checking..
    for torch... reg..leads.. etc..do not know if you would buy all new or use the acces you have with the new supply..
    might make sense to bite the bullet and go all new..
    clean slate..
    My Blue Stuff:
  5. #25
    Yes thats what I figured....I use Amazon and Ebay all the time ...that was my next step.
    GOOD NEWS.... I think I "fixed" the arc start problem.
    New Brass Ground Clamp, Lightly sanded and MEK cleaned- grd to machine plug and torch cable plug to machine plug, all torch bits and reground & fine sanded tungsten (red...all I have for now) put all back together.
    It fired about 25 arc starts....worked perfect.
    Theres hope.
  6. #26
    Nov 2003
    3,419
    Thumbs up
    Theres hope.
    Glad to hear that....... Thank Cruizer for that suggestion...
    My Blue Stuff:
  7. #27
    Compressor flange.....work in progress...welder's name is pirate...retired Delta airlines...
    Cleaned up-
  8. #28
  9. #29
  10. #30
    Nov 2003
    3,419
    if you debur the inside of the tube and remove fins before it is fitted and welded... there will be a lot less that needs to be ground out after welding..
    also it looks like he is cooking those welds... he might consider increasing the amperage and speeding up his pace...
    it should result in smaller tighter beads that still have enough penetration to be sound..
    My Blue Stuff:
