Results 11 to 20 of 34
    isn't that VQ35DE the same basic engine that Nissan puts in the 350Z....???
    should be some solid reliable performance info out there for it by now...
    would hope... anyhow..
    Any of this real..?? or is it vaporware..??
    http://www.injectedperformance.com/blog/tag/vq35de/
    Yes...same and I hesitate to say but I am now (in my mind) an expert on the whole Z/G modify engine working process.
    It turned into a "built engine" in Houston TX....but at my power levels prob not necessary but its done.
    Its real I think.
    I've been all over the country visiting shops in my travels and the ONLY place I trust is Dynasty....
    http://www.dynosty.com
    Check this out-
    http://www.garagejournal.com/forum/s...21477&page=120
    page 120 post# 2396.
    This guy is the private personal for the Jesse James Chopper shop.
    Nov 2003
    3,626
    Thumbs up
    as far as learning TIG...
    there are plenty of good online resources like this..
    http://www.millerwelds.com/resources...ur-skills/tig/
    not to mention youtube and weldingtipsandtricks
    http://www.weldingtipsandtricks.com/tig-welding.html
    do some studying..
    get some clean material to practice on.. prep it..
    setup your machine and practice... you will get a feel for it... not overnight but you will get it..
    put some Dire Straits,,, Clapton or other with a good beat on the shop stereo.. and have at it.. it will help develop your rythm...
    dip,,, move...dip... move...etc...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    do some studying..
    Yes thanks-
    Me attempting to tac a few months ago.
    Nov 2003
    3,626
    Thumbs up
    It's kinda like "Wax on... Wax off".........
    if you remember that movie...
    might seem repetative and pointless... bit it will get you there in time...
    http://www.youtube.com/watch?v=3PycZtfns_U
    http://www.youtube.com/watch?v=Bg21M2zwG9Q
    My Blue Stuff:
    Nov 2003
    3,626
    Thumbs up
    For practice cutting... fitting.... tacking and welding exhaust tubing...
    you might go down to a local muffler shop and see if they will let you dig in their scrap bin for some drops and shorts..
    they are usually car guys and will probably let you scrounge..
    and yes mild steel will weld a little bit different than stainless.. but close enough to be quite useful...
    Besides if you foodl-dey-duck up some free mild steel... it will not hurt like if it was expensive stainless..
    My Blue Stuff:
    You've been a great help but I'm still having the hf arc start problem. I fired it up yesterday and it would arc fire say 5 times then stop working. Then start working...an intermittent problem...frustrating.
    This machine with my back ground may have been a mistake purchase but it is what I have so I'm going to have to do some more trouble shooting.
    I need a brass ground clamp.
    With my machine should I get the 200 amp or the 300 amp?
    http://www.ebay.com/itm/300AMP-COPPE...item4d1df55382
    Nov 2003
    3,626
    Quote Originally Posted by scratchedup View Post
    it may very well be a matter of getting used to the machine and settings as FusionKing had suggested..
    developing consistant technique takes time and practice ... touching the tung to the work and lifting it off before each arc start... making sure the tung is properly prepped and collets + conductor in torch body are clean.. without tarnish.. corrosion,, spark burn..
    also... had you checked and tightened cable connections as Cruizer had suggested??
    ANOTHER approach you might think about is to sell the Dynasty you have and invest in a new one...
    it really depends on if your budget will allow... and if you wish to bypass the learning curve/grief of arc starts on the older one... probably have no problem selling it
    or even find a newer "Blue Lightning" equipped one on the used market...
    (Dynasty 200 with a serial# of LJ280222L and above are equipped with "Blue Lightning")
    And you could go directly to working on the car...
    My Blue Stuff:
    Nov 2003
    3,626
    Either one should be fine... but that 300 amp Lenco is reasonable enough.. a little overkill here would not hurt anything..
    My Blue Stuff:
