    May 2011
    Bossier Parish La.
    542
    Default Spray Tank Trailer Build
    I recently bought a forty gallon tank sprayer from Tractor Supply and needed a little trailer to haul it with. There was a version that comes with a wheel kit, but it is overpriced for what it is. Two wheels and a tongue to attach to a mower, and nothing else, not even a place to mount a spray boom. So I set about making my own version from material I already had. I wanted it to be four wheel, so it sits level when not hooked to the mower, and can be used independent of the mower moved by hand. I wanted it to back like a standard trailer not a tongue steered trailer. Used 1"x1" 4 gage tubing for most of it, welded with my MM140 and Hobart 0.030 flux core wire. Here's some pix of the build. Just getting started and figuring out piece sizes I need to cut and the wheels I have for it.
    May 2011
    Bossier Parish La.
    542
    Default Wheel attachment
    Here is where I started the supports for the rear axle and front casters. The start of the tongue is the last pic.
    May 2011
    Bossier Parish La.
    542
    Default rolling frame
    I got the frame in a rolling condition. Next is to make uprights with an extension off the back so there is place to mount a spray boom later, and hose wrap hangers on each side. I bolted the tank down to get some more measurements for the side pieces and get an idea what else I needed to do. I am making a little carrying area on the front to mount a trolling motor battery to run the pump on and carry the chemicals I will be mixing in the tank. It will have expanded metal in the bottom with a small rail around it to keep things in.
    May 2011
    Bossier Parish La.
    542
    Here is the completed frame primed and ready for paint, and then painted and assembled. I will build a spray boom for it later after another trip to TSC to get the nozzles and other stuff to make it with. The boom kit they sell, costs about $100, and I know I can make a better one for WAY le$$. The assembled pix will be in the next post.
    May 2011
    Bossier Parish La.
    542
    Default Completed
    Here's the completed pics of it ready to go to work spraying stuff on the yard.
    May 2011
    Bossier Parish La.
    542
    Default Made a Spray Boom
    So I made a spray boom to add to the rear cross bar. I used four spray nozzles and some 1/2" pvc. This is the first official use for the combo I needed to spray the yard for some unwanted weeds that came with some sand I had hauled in a couple of years ago to smooth out the yard in several places.
    The first pix are of the tank fully loaded, ready to start. Two ore f it in action, and the last after the spraying. I used some spray that is supposed to kill weeds, that does not kill grass. The stuff I used is in the last pic, it is from Tractor Supply Co.
