Results 1 to 10 of 11
    May 2014
    Rio Rancho, NM
    6
    Default Chop Saw Pipe Notcher
    Hi All,
    New to the forum and like what I have read.
    PART 1
    I am in the process of building a 1,550 long corral fence and horse stalls. At the age of 70, a cutting torch was not an option (shaky hands) and using a hole saw type notcher for the number of cuts I have to make on 1/4" tube wall, I would have more money in hole saws than pipe. Cutting pipe on a band saw or using a conventionally made chop saw didn't appeal to me either ...... grinding, oh no.
    I wanted the things everyone else wants
    Inexpensive tool
    Easy set-up & accurate
    Low cost consumables
    Able to be used in the field
    Here's what I created
    Purchased a Harbor Freight chop saw and cut the base off
    Made a base mounting plate and welded it to the chop saw head
    Since I am only able to post 4 pics at a time, I will continue with more pics in part 2, 3 & 4
    Your thoughts--good and the not so good are always welcome
    Paul
    Executive Director
    USMC Veterans Organization of America
    Enlistment: 1965-1967
    WIA Vietnam 11 May 1965
    Website USMCVOA.org
    May 2014
    Rio Rancho, NM
    6
    Default Chop Saw Pipe Notcher Part 2
    Part 2
    Made a base plate for the chop saw to mount to the tilt table
    Purchased this tilt table on EBAY---- $60 with free freight
    Fabricate a tilt table base plate to match mounting holes
    This photo shows the chop saw, tilt table and tilt table base plate assembly
    Continued on Part 3
    Paul
    Executive Director
    Website USMCVOA.org
    May 2014
    Rio Rancho, NM
    6
    Default Chop Saw Pipe Notcher Part 3
    Part 3
    At this point I was deciding on how I would make the working surface to notch pipe. I fabricated a base out of 2 x 2 sq tube, cut pieces of plate for fill. Most important was to cut a "V" into the base at the center line of the blade and welded in a 1-1/2 X 1-1/2 angle for the pipe to nest into. To clear angle cuts, a 1-1/4 cut on each side of the blade center line was cut to clear the blade as it will travel almost 2" past the center of the table. I got in a hurry and did not take photos of the table build. Everything was bolted to a Habor Freight work stand.
    Sample cut before completion
    Just before completion. Last item was to cut-out the section for the blade tilt.
    Continued on Part 4
    Paul
    Executive Director
    Website USMCVOA.org
    May 2014
    Rio Rancho, NM
    6
    Default Chop Saw Pipe Notcher Part 4 (finished)
    Part 4
    You've probably been wondering if this thing really works !!!!!!!
    These are cut samples at 28 deg on 2-3/8" pipe
    That's about as good as you can get--nice fit too.
    Here I was using the chop saw as a work table for axles I was building. The chain strap is a Harbor Freight item where I removed the chain from the grip and extended the anchor point by 2".
    If you want to see some of my other work, go to http://s1231.photobucket.com/user/sa...?sort=3&page=1
    Your comments are always welcome
    Thanks --- Paul
    Executive Director
    Website USMCVOA.org
    Oct 2009
    New Mexico
    43
    Good job Paul. I can see multiple uses for this set up and might just build one based off your idea.
    Nice. I use a method similar. I also have a JD2 "beast" notcher. But my go too for plain notches is a manual pipe notcher, it does sch 40 if thats what your using? its worth the money because it is fast and makes perfect notches.(i dont have an ironworker, if i did i would have pipe notching dies) http://www.ebay.com/itm/Baileigh-Man...item3a855ab743
    May 2013
    Cantonment, FL
    83
    Excuse my ignorance but, in use, do you cut half way thru the pipe and flip it over and cut the other half of the notch??Thanks,Mike
    May 2014
    Rio Rancho, NM
    6
    Quote Originally Posted by mbramble View Post
    Mike
    You are correct, cut half on one side and then cut the other half.
    If you setup an extension from the table and use a piece of pipe at 90 deg with adjustable setting, you can cut "exact" fit intermediate rails. Works really well in the field where there are many variables.
    Paul
    Executive Director
    Website USMCVOA.org
    May 2013
    Cantonment, FL
    83
    Paul,Thanks for the reply. I may have to look into building one of these from the old HF chop saw I have laying around!Mike
    Apr 2007
    Eastern Ontario
    101
    Paul, I like it, especially the angle iron seat to hold the pipe.
    Only thing I wonder about is the depth of cut - I assume you are eyeballing it and adjusting as the blade wears.Or maybe you have a gauge block that you cut down until you hit?
    When I rough cope pipe, I cut the sides off the end, instead of cutting a V out of the end. I find the result is the same and it's simpler to do on my chop saw. I set the angle on the fence, draw a line on the fence to align with the final length and chop off a moon shaped piece from each side. This gives me 2 through cuts so no depth to worry about. I think the end result is probably close to what you're getting. Bigger pipe gets some grinding, smaller just gets welded.
Tags for this Thread
